Old May 7, 2011, 03:31 PM
Default 1156 Evga p55 FTW Socket Burn (Foxconn Socket)
Happened just today, was using an i5-750, everything was stock settings (deafult BIOS settings, had used clear CMOS). This was a second hand board, purchased roughly a year ago?
Thanks Foxconn.
Old May 7, 2011, 03:35 PM
so it killed the cpu too?
hope warranty goes tru? :)
Old May 7, 2011, 03:42 PM
Nope, I'm pretty much screwed. From what I can tell the seller never registered the motherboard with evga because when I call they say it's not listed, so he just flat out lied it seems. I'm waiting on an e-mail response from him. The chip was from an OEM Dell so that's no good either.
However, the chip is alive although not well. CPU-Z shows it running at just under 1200 Mhz with a bus speed of 133.0 Mhz and a 9x multiplier.
Old May 7, 2011, 03:49 PM
clean the cpu pads make sure none are touching
you outa luck even if you registered it
evga wont cover socket burn
glad i got a lotess sofket
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old May 7, 2011, 03:59 PM
damn. thats not good.
remind me plz how you tell if you got one socket or the other? before you buy the board(looking up a review sample may snot mean much)
Old May 7, 2011, 04:03 PM
Why wouldn't they RMA it, that's pure bullshit. It's 100% a manufacturer error, I didn't even try to overclock.
Old May 7, 2011, 04:24 PM
post in there forums and see what gives, maybe they'll take pity on there pubic image? :)
Old May 7, 2011, 05:24 PM
sswilson's Avatar
Tell them your main SMP folder is down for the CC because of it..... ;)
Old May 7, 2011, 09:49 PM
That's what happens buying used sometimes. I have a buddy that gets burned (oops sorry) alot yet he keeps getting used hardware.
"What is the colour when black is burnt ?" - Neil Young
Old May 8, 2011, 02:53 AM
if they are nice they will charge $ to change the socket
guy i knew same thing happened with his classy they charged him 100$
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
[FS] 1156 combo, i7 860 & P55 FTW Eldonko Buy/Sell & Trade 7 April 7, 2011 08:14 PM
Possible 1155 socket burn? [TechReaction] Delavan Rumor Mill 7 January 17, 2011 04:07 PM
Socket 1156 build, good? t_mo_t New Builds 9 March 17, 2010 07:56 AM
EVGA P55 FTW WITH FOXCONN muffler CPU's and Motherboards 15 December 23, 2009 02:50 PM
Cooler for Socket 1156 I5... Ryoohki Air Cooling 3 October 3, 2009 01:40 AM
