Old January 27, 2008, 07:55 PM
BALISTX's Avatar
Default ARGH Decisions Decisions
I have been reading reviews left right and center on the new Intel E8400 and now I'm wondering if I made mistake by buying the Biostar Tforce 560 board. I haven't bought the AMD 5000 BE yet, so here is where my dilemma is. Do I stick and continue to build the AMD system or do I cut my loses sell the Biostar board for $65 to a friend at work (only losing about $10 on the board) and then get the Gigabyte P35-DS3L and the new E8400?
I have my ram ordered and it's the 2GB Mushkin EM-6400.
The only other issue I am wondering is the new P35-DS3L boards shipping with a new BIOS that supports the new 45mm cores, since I no longer have my E2180 CPU where I can put in and update the BIOS?
Your input is greatly appreciated.
Heatware
HWBOT
Old January 27, 2008, 07:59 PM
Dude...
Two words ... 8400 love :D
Old January 27, 2008, 08:20 PM
Cptn Vortex's Avatar
I would easily suggest selling the board, and going with the combo you have listed. Great board, amazing CPU. The AMD is good, and great for the price, but the intel is just plain fast
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old January 27, 2008, 10:01 PM
magictorch's Avatar
Default depends on the gpu
If you want to really OC the GPU or get a very "powerful" soon to be released model you should get the new 8400 cpu......preferably cheaper than NCIX has it listed.
Old January 29, 2008, 08:32 AM
low351's Avatar
I agree. Sell the AMD board and go intel. I went the AMD route and now I'm stuck into it because of Microsoft OEM rules. Even if I came up with the cash for a new board and cpu I'd still have to pony up for a new Vista or see if I could sell some sob story of burning MB components and get my license reset.
I have an ASUS M2A-VM (bad board for overclocking since it doesn't lock the PCI-E speeds when you change the frequency) and a X2 6400 BE and I'm not impressed with the speed. I had a 4800+ before and other than my Game FPS going up about 10fps I don't see much difference in general use.
Old January 29, 2008, 08:38 AM
Babrbarossa's Avatar
Glad to see you're getting a new build together- cheers!
argh, anyone know why my DS3L wont save any BIOS settings? donimo Overclocking, Tweaking and Benchmarking 19 January 19, 2008 10:41 AM
Argh, ok now memtest won't work with old ram either donimo RAM 1 December 10, 2007 11:02 AM
DDR Ram decisions. chibi_man RAM 6 December 7, 2007 08:55 PM
