-   -   P8P67 deluxe AIsuite blue screens (http://www.hardwarecanucks.com/forum/cpus-motherboards/42906-p8p67-deluxe-aisuite-blue-screens.html)
boris_37 April 28, 2011 06:12 PM
Hi,
So i got my new pc all setup, seems stable enough but every time i try the AIsuite autotune it throws me to a blue screen claiming hardware error. I can play games, do anything and it is fine but AIsuite autotune will not work. I have not touched anything in bios yet so i am not sure. Are blue screens during the autotune normal? I only let it run once and it blued so i updated and tried some stuff, then ran it again, blue screen...
I ran memtest, have run some benches and don't know why it would be blue screening. I checked and updated windows because i have seen that previously if there we blue screens it was a windows issue(maybe not?).
Computer is as follows
Windows 7 - 64 bit SP1
Intel 2600K
P8P67 Deluxe
G.SKILL Ripjaws X F3-10666CL7D-8GBXH
Zotac GeForce GTX 480 AMP!
2x 64gb Crucial C300
Wurmer May 1, 2011 05:15 AM
I don't exactly know what it is but I had a tone load of trouble using the IA suite specifically the OC feature and my rig was running good for pretty much every thing else but that program. It might just be the program itself. OC was possible but now by auto tuning. I don't know how exact it is but a friend of mine told me that this program is known to be buggy. It is possible, I don't for sure but I can tell you that the program was really working well on my previous AMD rig. BTW my is rig is pretty similar to yours.
boris_37 May 1, 2011 08:15 AM
Okay thanks, I will try doing it manually. I just wanted the lazy way out originally. I am having tons of issues with my video card, i don't "think" that is why... but it could be?
I'm getting the dreaded driver stopped responding. Could be a dying card, in the works of explaining it to zotac.
