Old January 26, 2008, 03:45 PM
MaDDN3ss's Avatar
Default HTPC Motherboard
I am just finishing up a budget HTPC and was curious what you people thought of these two motherboards.
eVGA 112-CK-NF77-A1
eVGA nForce 630i / e-Geforce 7150 w/ DDR2 800, 7.1 Audio, Gigabit Lan, PCI-E x16, HDMI, DVI-HDCP
XFX MG-630i-7109
XFX nForce 630i / Geforce 7100 w/ DDR2 800, 7.1 Audio, Gigabit Lan, PCI-E x16, HDMI, DVI-HDCP
They are both pretty much the same but have a few differences. For example:
eVGA vs XFX
Lifetime Warranty 2 Year Warranty
No e-SATA e-SATA
GeForce 7150 GeForce 7100
$94.95 - $15.00 MIR $89.95
Just wanted to know your opinions to help me decide which one to buy.
Thanks
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe." - Albert Einstein
Old January 26, 2008, 05:03 PM
b1lk1's Avatar
After being one of the many unhappy EVGA 590SLI owners, I would not recommend them. They may actually give that board some support since it is S775, but they are not nearly all they are cracked up to be. XFX for the win.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old January 26, 2008, 05:14 PM
If you haven't already bought the cpu I'd suggest going AMD and pick up a Gigabyte GA-MA69GM-S2H mATX motherboard.
It's fully loaded and has everything you could think of. Paired up with a X2 5000+ Black Edition or just a normal one (2.6GHz) or a newer Phenom quad core would be great for an HTPC.
I just finished a build this week with a X2 5000+ and this Gigabyte board and I'm quite pleased. It can handle HD media with the onboard X1250 GPU since it uses the AVIVO decoding. It's the 690 chipset on this board.
Check it out, I think you'll like it. Overclocking is really, very simple on this board as well.
Cheers,
Mike
Old January 26, 2008, 06:01 PM
MaDDN3ss's Avatar
I actually have everything but the motherboard.
Just using a cheap case until I can afford a better one but here is the set up thus far...
Ultra MicroFly mATX case
Ultra 600W PSU
E6300
2GB PC2-5400 Corsair
300 GB Seagate SATA 8MB w/ NCQ
Hauppage WinTV PVR150
Creative Audigy 4
Plans are to add a NAS box and a couple 750GB or 1 TB SATA II drives after.
Just wanted a mobo that had HDMI out. I like the ASUS P5E-VM HDMI but I really didn't want to spend $150 on the motherboard, hence my options listed above.
Old January 28, 2008, 05:40 PM
darksideleader's Avatar
what i seriously don't get is why they only put 2 ram slots on the motherboard, its not like an extra 2 won't fit or anything...
Old January 28, 2008, 05:41 PM
bobletman's Avatar
Go with the XFX mobo for sure, Just make sure that if your getting OCZ ram that it will have the proper voltages cause sometimes the two can be a bit fidgitey with eachother.
Old January 28, 2008, 06:27 PM
JD JD is offline
I'd go for the eVGA myself as it has the slightly better graphics and is cheaper (after rebates). Still it's only $5 more.
I'm fairly sure both boards are of the same quality as they both just look like reference designs.
Show me your HTPC Croman HTPC Systems & Software 38 September 23, 2008 09:31 AM
HD-HTPC Idea. BALISTX HTPC Systems & Software 10 March 13, 2008 05:31 AM
starting HTPC david17 HTPC Systems & Software 13 January 4, 2008 04:13 PM
Budget HTPC BALISTX HTPC Systems & Software 4 May 28, 2007 08:16 AM
Looking to build a HTPC? Babrbarossa Press Releases & Tech News 0 February 16, 2007 11:51 AM
