<~----> i7 2600k overclocking what is this... - Hardware Canucks
Old April 20, 2011, 12:25 PM
Default i7 2600k overclocking what is this...
First of all what is with this new shitty bios even in the advanced mode this thing i don't even know what to call it. it's like a monstrosity to me second of all WTF is with the over clocking this thing is beyond making me rage i change my multiplier to 40 for a 4.0ghz oc and nothing happens nothing at all the CPU doesn't change speeds at all what is this am i missing something here also as soon as i change the multiplier turbo mode gets forced on. I miss over clocking my i5 760 that was so easy to OC i thought they made this simpler my IQ goes down every time i go into this bios
i5 3570K @ 4.5GHZ // MSI-G45 // 16GB Corsair Vengance Blue // XFX 7970 // SilverStone Raven 03
SteelSeries 6Gv2 // SteelSeries Kana White // Steelseries Siberiasv2 White // BenQ XL2410T // Samsung 2233rz
Old April 20, 2011, 12:45 PM
1) UEFI bios are awesome in so many ways and much better than the old style
2) Have you tried loading up your processor?
Old April 20, 2011, 12:49 PM
krazyups's Avatar
I have had no problems overclocking my 2600k (only 4GHz right now), but I noticed what enaberif mentioned, it only becomes active once a load is applied to the processor.
Edit: I just checked your specs, and I have the same motherboard, I quite like the new bios. It is as easy as you think it is, trust me, I'm a complete overclocking noob.
Old April 20, 2011, 12:55 PM
well yeah im running bench marks and its showing it as 3.4ghz...
Old April 20, 2011, 12:58 PM
krazyups's Avatar
Hmmm, that's very odd. All I did was change the multiplier and the voltage, and make sure that C1E, C3 and C6 (I believe these last two are correct) were enabled, along with turbo mode (auto enabled like you mentioned), and cpuid showed 4GHz when I was folding.
Old April 20, 2011, 01:40 PM
i mean my i5 760 is getting way higher bench marks than this computer... it's pretty frustrating
Old April 20, 2011, 01:46 PM
Eldonko's Avatar
Hardware Canucks Reviewer
If your multi is dropping and you dont want it to then disable C1E and speedstep.
Old April 20, 2011, 03:08 PM
ok so I'm comparing my i5's benchmarks to my 2600k's benchmark and i'm noticing something here
i5 760 CPU Score
51540.98
i7 2600k CPU Score
30271.01
uhh?
Old April 20, 2011, 03:11 PM
i5 760 CPU Score
51540.98
i7 2600k CPU Score
30271.01
uhh?
What are you using to benchmark these things?
Also try to tighten up your memory and go from there.
Old April 20, 2011, 03:47 PM
well i didn't blue screen on a 4.8ghz 3d mark benchmark on air (: so i'm happy cant wait to put my water cooling in this next month and try some higher speeds
Help for a OC I7 2600k Alpine Overclocking, Tweaking and Benchmarking 39 April 4, 2011 12:54 PM
2600k Overclocking Wi-Fuzzy Overclocking, Tweaking and Benchmarking 16 March 27, 2011 06:09 PM
Questions... i7-2600k vs SR-2 Grampa HardwareCanucks F@H Team 29 March 11, 2011 04:21 AM
2600k benchmark botat29 CPU's and Motherboards 12 January 17, 2011 02:03 PM
Intel i7-2600k Zink HardwareCanucks F@H Team 19 January 7, 2011 12:39 PM
