Old March 30, 2011, 04:50 PM
Default Dell mobo
ive got a dell inspiron 530 and im looking to upgrade the gpu because my 8300 fried a while back. When i took the 8300 out I think i might have done a little bit of damage to the clip at the back of the pci-e lane. Is it still safe to put a new card into it? Also wondering if anyone else has ever upgraded a dell
Old March 30, 2011, 04:57 PM
SugarJ's Avatar
If it's just the clip that's broken it should be fine. If there's any damage to the slot area where you insert the card, I wouldn't.
As for your upgrade question, make sure the card you are getting doesn't draw any more power than your old one. Dells usually have "just enough power" for their standard configurations and no more, in my experience.
Old March 30, 2011, 05:00 PM
from the looks of the case they left just enough room for the power supply too, is there still a possibility to upgrade it?
Old March 30, 2011, 07:16 PM
Soultribunal's Avatar
Sometimes you can, sometimes you can't. Depends on the particular Dell.
Shoot us some pictures if you can on the PSU front, and take a look at the connectors on the supply as well to ensure there are no 'special' connectors.
ST
www.realhardwarereviews.com
Old March 30, 2011, 10:00 PM
if i get a new card and power supply and the gpu doesnt work on the motherboard then which motherboard would you recommend for cheap and would it work to replace a dell mobo with a 3rd party one, im assuming that i could probably get a better one for $30-40
Old March 31, 2011, 04:43 AM
I don't think you'll be able to buy a new socket 775 board for $30-$40 new. You'll probably have to buy second hand. This is the cheapest I could find at ncix.
NCIX.com - Buy MSI G31TM-P21 LGA775 G31 mATX DDR2 PCI-E16 2XPCI Video SATA LAN Sound Motherboard - MSI/MicroStar - G31TM-P21 - in Canada
Dell 2209WA $209 @ Dell MrDiaz Display Units 15 March 21, 2010 01:16 AM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
FS: Retail e6600 ---- DFI 975X Mobo ----- Logitech X-530 ------ LF: Phenom Mobo thatguy Buy/Sell & Trade 15 May 1, 2008 09:38 PM
Can shorting a mobo, on the case, ruin that said mobo? mattlef CPU's and Motherboards 25 April 23, 2008 03:00 PM
