Old March 28, 2011, 09:18 PM
Question P8P67 Deluxe and 2600K cooler?
Looking for an air based cooler for the Asus P8P67 Deluxe motherboard and a SandyBridge 2600k CPU. The Deluxe motherboard has problems with some coolers and their back plane plate. Any one here using a cooler for overclocking this CPU and the Deluxe motherboard?
Old March 28, 2011, 09:40 PM
Delavan's Avatar
I replied in your post on NCIX forum...lol you double poster...
P8P67 Deluxe + Noctua NH-U12P no issues
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old March 29, 2011, 04:44 AM
I'm using the Hyper 212+ and it doesn't block any of the RAM slots which is why I like this cooler.
Doesn't a pretty good job with dual fans.
I've got my 2600k at 4.5GHz and at load (prime95) it maxes out at 65C, which is decent.
Old March 29, 2011, 05:59 AM
I sure hope my megahalems rev B is good. I'm sure it will be... but still would be super disappointed if it wasn't.
I bought the same combo, my stuff should arrive on wed or thursday. So pumped been early core 2 since i got a new pc.
Heat
Old March 29, 2011, 07:27 AM
I don't see why should there be compatibility issues when on the box of the heatsink is mentioned LGA1155/LGA1156? I doubt heatsink manufacturers would release their products as something that can't fit properly.
Old March 29, 2011, 08:17 AM
francisw19's Avatar
I can recommend the Noctua NH-D14 I'm using. It has no problem with fitting on my motherboard and the backplate fits fine without any issues.
I have my 2500K at 4.4GHz right now and Prime95 loads temps were 53C max on my warmest core.
The only disadvantage is that it's quite large and so you can't use RAM with really tall heatsinks.
Old March 29, 2011, 08:47 AM
Works fine. If you have tall RAM like the Vengeance, just move the fan up a little higher.
Can hold a 2600K @ 4.8Ghz with a decent 1600 RPM fan 24/7 Folding.
heatware
Old March 29, 2011, 08:55 AM
Going to use Corsair XMS3 2x4GB in the motherboard. I can get the Hyper212+ locally but would have to order the NH-U12P online which makes returning it if there is a fit problem, costly.
SLI 570 vs Crossfire HD6970 on SB 2600K+ASUS P8P67 Deluxe Delavan Video Cards 21 April 3, 2011 10:47 AM
600T and P8P67 deluxe Ging9 Cases 2 March 27, 2011 05:18 PM
ASUS P8P67 Pro Coach CPU's and Motherboards 7 March 13, 2011 01:28 PM
Asus P8P67 Deluxe USB3.0 Front Panel Issue Eluder CPU's and Motherboards 1 January 28, 2011 08:40 AM
ASUS P8P67 Deluxe [Hardware Secrets] ZZLEE Reviews & Articles from the Web 1 December 13, 2010 06:52 PM
