Old March 25, 2011, 06:26 AM
Wurmer's Avatar
Default HS compatibility
Just a quick question folks,
I have an hydro 50 from Corsair, I know it works for socket 1156 but will it work with socket 1155? I guess it should because AFIAK, both sockets use the same bolt patern !
Old March 25, 2011, 06:36 AM
From NCIX H50 topic: "Yes, 1155 and 1156 use the same hole spacing on the mobos."
I guess you were right.
Software compatibility scottman O/S's, Drivers & General Software 4 November 4, 2009 03:03 PM
IFX-14 Compatibility CORE Air Cooling 3 July 1, 2009 05:05 PM
Vista Compatibility Bullterrier Troubleshooting 7 June 16, 2009 01:30 PM
Curious about Compatibility Diego22 New Builds 8 May 27, 2009 04:31 PM
Compatibility - P6TDv2 and GTX285 SkyChief Troubleshooting 16 April 21, 2009 06:18 AM
