Old January 21, 2008, 02:44 PM
misterlarry's Avatar
Default Is GA-P35-DS3L sufficient for OCing E8400/E8500 Wolfdale?
Gigabyte says it will accept 45nm, but is it a good board to go with? Would one of the new Gigabyte "Power Saver" boards be better? Thanks a lot!
Gigabyte GA-P35-DS3L ATX LGA775 P35 1333FSB 1PCI-E16 3PCI-E1 3PCI SATA2 Sound GBLAN Motherboard
Old January 21, 2008, 04:23 PM
MpG's Avatar
MpG MpG is offline
The few reviews that I've seen on boards with Gigabyte's Power Saver ability have found that it actually tends to reduce the maximum overclock, since the boards don't quite switch modes fast enough to handle load spikes at higher voltages.
Old January 21, 2008, 06:02 PM
3.0charlie's Avatar
The DS3L is a very good, cheap ($$$) board that has a lot of features BIOS-wise, allowing it to reach some very nice numbers. I should be a nice combo. I'll try that CPU, or a Q9450 on my DS3L...
Hydro-Quebec is salivating...
Old January 22, 2008, 10:44 PM
biff's Avatar
My GA-965P-DS3 has my e6300 chugging along nicely @ 466x7 (~3.3GHz) with stock cooling and volts so I can't see there being a problem. They're kind of vanilla boards compared to what's out there but they're no slouch for O/Cing.
Old January 23, 2008, 11:29 AM
turtletrax's Avatar
It seems that mobo manufacturers cheap out on the power regulation on lower end boards mostly. With the lowered power envelope with these 45nm chips, it should be OK for OCing in comparison to the Quads.
"It's time to kick gum, and chew ass. And I'm all out of gum."
Dick Kickem
Old January 25, 2008, 04:26 PM
SugarJ's Avatar
3.0Charlie, you have both a GA-P35-D3SL and a -D3SR? What is the difference between them? Audio DAC? I've been looking at these boards as well. If that's the only major difference I'll go with the D3SL because I have a XiFi card, and don't care about onboard sound.
Old January 25, 2008, 05:44 PM
Major difference is RAID, if you don't need it, just the the L.
Old January 25, 2008, 06:17 PM
3.0charlie's Avatar
I have the DS3R since it was offered to me for a very good price - I don't even run RAID on it. Get the DS3L, you won't regret it. Slap a nice fan on the Northbridge, and you're good to go. I use a Spot Cool just for that.
Old January 25, 2008, 06:19 PM
slugbug's Avatar
The price at DirectCanada is now $86.99
Old January 25, 2008, 11:27 PM
biff's Avatar
FWIW, I have the P965 version of the DS3's and had it up to 480MHz FSB tonight and I think it was my RAM holding me back. I have no doubt the P35 version would run at least as good if not better given the reputation of the P35. Fantastic boards for the price.
FS: Intel Core 2 Duo E8500 OEM $260 zoob Buy/Sell & Trade 2 February 21, 2008 10:02 PM
Is NVIDIA 7xxx sufficient for... Mr. Cipher Video Cards 9 February 7, 2008 10:34 AM
EVGA 680i now supports Wolfdale! Babrbarossa CPU's and Motherboards 3 January 24, 2008 12:58 PM
Does your mobo run Yorkfield or Wolfdale? (Anandtech) Babrbarossa Reviews & Articles from the Web 8 November 3, 2007 09:16 AM
Intel completes 45nm 'Wolfdale', 'Yorkfield' architecture Supergrover Press Releases & Tech News 2 January 19, 2007 07:52 AM
