Old January 20, 2008, 11:37 PM
Default Gigabyte P35C-DS3R
Any good?
Also, does it support PCI 2.2 (am completely ignorant about PCI versions and compatibility)
Thanks, guys
Old January 21, 2008, 06:43 AM
3.0charlie's Avatar
I have one with a Quad - see sig. Runs great, needs a fan on the NB cooler though. As for PCI-E 2.2 compatibility, I have no idea too. But I'm running a 8800GT without problems.
Old January 21, 2008, 07:07 AM
sswilson's Avatar
The new PCIe spec should be compatible with all but the oldest PCIe boards, but will not be able to take advantage of the better bandwidth offered by PCIe 2.
That said.... I haven't been able to find anything on-line suggesting that current cards can use the extra bandwidth offered by PCIe 2 so it's probably a moot point.
For intel chipsets, you have to go with at least the X38 to get PCIe 2.
Old January 21, 2008, 09:18 AM
Ugly n Grey's Avatar
The bandwidth increase was primarily designed to help in scenarios of bus loading like multiple GFX boards, workstation setups etc...
It might be beneficial with the upcoming 2 GPU single slot boards, but no one knows yet.
I've been eyeing this board too - looks like a nice Water cooling candidate for a daily workstation.
Old January 21, 2008, 04:32 PM
3.0charlie's Avatar
It's a good board package: low price, DDR3 compatibility, 45nm CPU compatibility too. I wanted to invest in a board and not to change it in 2 years. It should be just fine. And it is my daily workstation.
And its She-Who-Must-Be-Obeyed's rig too. So it better be stable, 'cause I'll hear about it.
Old January 21, 2008, 05:13 PM
Default thanks, but
Thanks guys. But I meant regular PCI, not PCIe. I think all PCI is compatible, and all PCIe is compatible, but they are not compatible with each other. I ask because I got a PCI 2.2 sound card off NCIX (Razor AC-1, bundled with HC-1 headphones for more than half off- seems like a deal) and just realized I had no idea how different PCI connections worked. I know PCIe, because its relevant for vid cards, but I don't have a clue about regular PCI. any advice would be helpful. thanks.
Old January 21, 2008, 05:14 PM
All PCI is but not all PCI-E is.
Some boards that use PCI-E 1.0 or 1.0a won't work with a lot of the new cards.
Old January 21, 2008, 08:06 PM
That's pretty much what I thought. Thanks.
Ram for a GA-P35-DS3R sircuster RAM 12 April 7, 2008 10:35 AM
ds3r SB heatsink Mr. Cipher Air Cooling 22 February 28, 2008 02:39 PM
DVD/RW drives not working on GA-P35C board. Malam CPU's and Motherboards 0 January 27, 2008 10:47 AM
Gigabyte QC issues - DS3R boards rgsaunders CPU's and Motherboards 4 September 23, 2007 11:54 AM
Synthesis of four Gigabyte P35-DS3R reviews Babrbarossa Reviews & Articles from the Web 4 June 4, 2007 10:18 AM
