Old March 12, 2011, 12:10 PM
Coach's Avatar
Default ASUS P8P67 Pro
Does Q-Fan Control on a P8P67 PRO work with 3 pin fans? Thanks
Old March 13, 2011, 04:19 AM
EmptyMellon's Avatar
Arrow No.
No, it should not. ASUS FAQ: ASUSTeK Computer Inc. -Support- FAQ P5B Deluxe FAQ CPU Q'Fan function not working
Old March 13, 2011, 08:10 AM
Coach's Avatar
Thank you
Old March 13, 2011, 08:11 AM
Coach's Avatar
but umm your link concerns a different mobo correct? Are you sure the same applies to the one in question?
Old March 13, 2011, 09:52 AM
JD JD is offline
I don't know for certain, but some ASUS BIOS'es allow you to select your fan type and then Q-FAN will work. If you skim through the manual and look at the BIOS screens, you'll probably find it if it has such an option.
Old March 13, 2011, 10:06 AM
Coach's Avatar
This is all I see in the manual. I have yet to buy this mobo and I am trying to figure this out before hand. My D14 uses 3 fans atm none of which are pwm.
Old March 13, 2011, 10:10 AM
JD JD is offline
So that's a Noctua fan? Why do you need to vary it's speed then? It's already pretty quiet at full speed.
Seems like Q-FAN probably won't work as there's no PWM/DC option.
Old March 13, 2011, 01:28 PM
Coach's Avatar
Thanks for your help :)
P8P67 Pro disables boot drive selection when in RAID mode lowfat CPU's and Motherboards 0 February 4, 2011 05:43 PM
Asus P8P67 Deluxe USB3.0 Front Panel Issue Eluder CPU's and Motherboards 1 January 28, 2011 08:40 AM
2500K + P8P67 Pro Overclocking Realityshift Overclocking, Tweaking and Benchmarking 0 January 24, 2011 11:20 AM
ASUS P8P67 Deluxe [Hardware Secrets] ZZLEE Reviews & Articles from the Web 1 December 13, 2010 06:52 PM
