Old March 9, 2011, 11:31 AM
Cowboy's Avatar
Default Give me the lowdown on Sandy-Bridge
So I know basically what it is (2nd gen i7's etc..) but what does it MEAN? What does it add to the table that makes it so awesome?
I've heard that some boards can Overclock, but others can't... Which ones do, and how do I tell?
I've also heard that some boards support switchable graphics, but others can't... Which ones do, and how do I tell?
Also is it true that the boards that support Overclocking do NOT support switchable graphics?
This is all so confusing...
Do they at least use the same ram standard as lga1156??
Old March 9, 2011, 11:34 AM
lowfat's Avatar
H67 boards support the on-GPU graphics. P67 boards do not.
H67 boards can not overclock. P67 boards can.
You need a 'K' CPU to do any sort of overclocking.
Ram really doesn't matter since it has no impact on overclocking w/ Sandy Bridge since you are just adjusting the multiplier.
Sandy Bridge is aewsome because it is fast and overclocks like a champ.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 9, 2011, 11:35 AM
1155 is kind of confusing because people automatically assume its the upgrade from 1366 and its not. Its actually the upgrade from 1156.
With that said the 1155 platform basically overclocks better with less heat and power.
Old March 9, 2011, 11:39 AM
Cowboy's Avatar
Ok so if I wanted to have switchable graphics, i.e my GTX 560Ti shuts off by-itself to save power... I need to get an h67 board?
But I can't overclock... at all??
And why do I need a K cpu? Do they have unlocked multipliers or something?
Old March 9, 2011, 11:43 AM
lowfat's Avatar
You can't adjust the bclk more than a few MHz and run the risk of data corruption on your HDDs. Which is why you need an unlocked 'K'.
Queen of Dreams WIP
Big Lian Li
Complete
Old March 9, 2011, 11:44 AM
Cowboy's Avatar
Wait so what does the bclk have to do with hard drives now? is it because of the NB and SB being integrated into the cpu now?
Old March 9, 2011, 11:50 AM
you can, but intel says not to play with the bus because it messes things up. id probably take their word on it.
wait for z68 or whatever its called, integrated graphics and oc on one board..like a miracle!
yes, k = unlocked multis = overclock easy
Old March 9, 2011, 11:52 AM
Cowboy's Avatar
and what kind of OC's are expected? What could you get with air/low end water?
Old March 9, 2011, 11:56 AM
4.5 on average on stock cooler. then the remaining 50% of chips can do anywhere from that up to and some above 5ghz.
there were some numbers in one thread...
Old March 9, 2011, 12:07 PM
lowfat's Avatar
honestly I wouldn't overclock at all on the stock cooling. It sucks. At stock clocks folding@home takes me above 70C. 4.6-4.8GHz isn't unreasonable on decent air cooling though. Watercooling won't likely gain you anything either.
Queen of Dreams WIP
Big Lian Li
Complete
should i go for sandy bridge now or wait N.E.A CPU's and Motherboards 27 February 27, 2011 12:41 AM
First build, Sandy Bridge Atmax New Builds 6 January 26, 2011 03:46 PM
Sandy bridge notebooks? dustin1706 Mobile Computing 13 January 24, 2011 07:34 PM
what is intel Sandy Bridge? kuziwk Rumor Mill 18 February 26, 2010 06:40 PM
