<~----> E6750 temp help? - Hardware Canucks
Old January 17, 2008, 06:42 PM
Default E6750 temp help?
I'm running my E6750 @ 3.5 GHz stock heatsink 438x8
After running orthos for 1hour both cores are steady around 55C is this too hot should I lower my clock speed?
Old January 17, 2008, 07:00 PM
Prof. Dr. Silver's Avatar
Nah....but you're getting there....You might want to change your HS into something better! Is better for your CPU! Remember.....Cooler = Better!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old January 17, 2008, 07:24 PM
magictorch's Avatar
Default not that bad
That seems ok for stock volts. But as Prof says try and work on the temps.
Your about the same as my E6750 (with a sytheninja revB and 1 NFP-12 fan). That said Im looking to improve these temps with some MX-2 another fan and the thermalright extreme heatsink.
I think your ok for gaming but cutting it fine for something like folding.
Old January 17, 2008, 10:43 PM
donimo's Avatar
where are you reading temps from?
use core temp 0.96 if you're not.
Mine is at 43C in coretemp at 3.6GHz with the TRUE right now
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old January 18, 2008, 11:42 AM
my CPU temp is 46C @ 3.5Ghz and the temps on both cores is at 55C
Old January 18, 2008, 11:54 AM
donimo's Avatar
with coretemp? sorry to be repetitive but lots pf programs can read the core's temps (speedfan etc), but only the program CoreTemp does it right...
Old January 18, 2008, 01:05 PM
i use speedfan when i try and use core temps i get error msg saying unable to load drives and the program opens and closes until i end the task
Old January 18, 2008, 01:09 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Nothing to worry about.
Old January 18, 2008, 01:10 PM
donimo's Avatar
ok, speedfan is notorious for false core temps though, I would say to be safe to add at least 10 to your temps to be safe.
Try uninstalling it right off the PC and download the latest one here and try again
Core Temp
Old January 18, 2008, 01:37 PM
magictorch's Avatar
Default speedfan and coretemp
I get a 15oc temp difference between speedfan and core temp 0.94.
BTW Domino you really got some nice temps with that TRUE
WTB: E6750 or EVGA 8800GT tgraszat14 Buy/Sell & Trade 0 March 3, 2008 10:56 PM
Need help OC'ing e6750 on an Asus P5K vertex112 Overclocking, Tweaking and Benchmarking 9 February 4, 2008 05:52 PM
Reasonable OC for E6750? Ed_JS Overclocking, Tweaking and Benchmarking 15 September 29, 2007 05:00 AM
E6750/E6850 Unavailable? Dus CPU's and Motherboards 3 August 6, 2007 08:28 AM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
