Originally Posted by Jdroflet Same here on stock HSF with core temp V0.96.1, Nice to see I have baseline now.
Open air bench, room temp 20 (it's winter eh :)
Core Idles 26/28
Orthos for 1 hour and cores for both range at 48-51 C New build so not burned yet.
Running Speedfan too and it's core temps always off by about -15C
I noticed on the GA-P35-DS3L With bios smart fan set to auto it did NOT bump the fan to full speed and resulting tests was a steady 55C on both cores. It only spun the fan up to abut 1400 RPM, with smart fan disabled it runs at 2039 RPM.
Thanks, John. |
My ds3L is the same, it only bumps up the speed when the sensor it uses for CPU (which is waaaaay off) temps gets to about 50C, which is like 75 in coretemp or something...
You can load eztune up with windows startup and set it where you like, works for me, but I run it at 100% so dont bother...
