Old March 1, 2011, 03:40 PM
Default Help Quick!! Whats Better!
Alright I have quite a few options here and only want to keep 3 the other 2 have to go so what would be my best options at this point in time. I've been trying to research as much as possible but am so lost with knowledge right now that I've confused myself.
Thanks!
1) Gigabyte EX58-UD3R, i7 920 (DO) @ 2.6GHz, 6GB Mushkin 1600 Triple Channel RAM, 150GB Raptor, EVGA GTX285 , Antec 1200
2) Gigabyte GA-890GPA-UD3H, 1055t @ 3.7GHz, 4GB Mushkin 1333 RAM, 1TB Seagate, BFG GTX280, Antec 900
3) ASUS P6X58D-E, i7 920 (DO) @ 2.6GHz, 8GB GSKILL RipJaws 1333, 1TB HD, 2x4870 512MB, HAF 922
4) M4A89GTD PRO/USB3 & 1055t
5) DH67CL + i5 2400
Comp1 (Mine) : ASUS P9X79 LE, 3960X, 16GB Corsair Vengence 1333, PNY 770 4GB, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : ASUS Sabertooth P67, i7 2700K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, EVGA 660, Corsair 1000HX, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Gigabyte 770, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 120
Old March 1, 2011, 03:53 PM
If you had to let go 2 of those, I would choose:
#2) BFG; before they fade from people's memory.
#5) It has higher resale value since it's current gen.
Old March 1, 2011, 03:59 PM
sell the lot till it holds value and get one-two sb builds.
Old March 1, 2011, 04:07 PM
I should have been more specific what CPU/MOBO combo's would I be best to keep and best to get rid of and yes I completely plan to go Sandy Bridge once I see some good deals :)
Old March 1, 2011, 06:44 PM
I should probably mention this is what I do and use them for
1) Mine : Will be strictly gaming and the odd research and browsing
2) Wife's : This is the Media PC for streaming to the xbox 360 and also another tv that has an asus o!play air, as well as music, and slight gaming, also does adobe etc...
3) Kid's : Gaming mostly and research that's about it.
Old March 2, 2011, 07:35 AM
GT7R's Avatar
Keep 1,4 & 5.
Old March 2, 2011, 09:42 AM
I should mention that I'm only interested in which CPU/MotherBoard combo's to keep as I can swap all the other stuff quite easily :)
Thanks again so far looks like 1,4,5
Which motherboard is the best one I have for the 1055t's? The Gigabyte or the Asus?
whats this kendallcschm CPU's and Motherboards 6 December 22, 2009 11:53 AM
quick quick can we do 4 gtx 285 sli? hohohee Video Cards 7 June 7, 2009 10:14 PM
Whats the best MB i can get for ??? WolfBane CPU's and Motherboards 12 May 29, 2009 05:31 PM
Whats Better trayton CPU's and Motherboards 4 May 1, 2009 08:16 PM
whats this mean ? Jim CPU's and Motherboards 8 July 25, 2007 05:39 AM
