Old February 28, 2011, 12:58 PM
Default What to do?
Hey guys,
I need some upgrade advice here... I just picked up an evga GTX 580 SC, so I'm good on the GPU front.
My system is as follows:
  • Intel Q6600 G0 stepping (want to upgrade)
  • Gigabyte EP45-UD3P (want to upgrade)
  • 4GB OCZ Reapers 1150MHz (want to upgrade)
  • Silverstone OP-750
  • Evga GTX 580 SC (upgraded from a GTX 470)
  • TRUE 120
  • 2x 640GB WD Caviar Blacks in RAID0
  • 1TB WD Caviar Black storage drive
  • 500GB Seagate storage drive
  • Auzentech Prelude
I game. Mainly games like BF:BC2, COD, other FPS shooters, some Source games. I also do a fair bit of video encoding using TMPGEnc, mainly converting .MKVs to .WMVHD files.
So what's the best for my situation? Wait till SB mobos come in? Wait for IB? Buy used 1156 or 1366 setups?
I would like to upgrade the components that are bolded & italicized. I would like to keep my PSU if posible. I have no issues buying used. I also do not have a desperate need to upgrade, but the main components of my PC are approaching 4 years now, I think it's time for a change...
Old February 28, 2011, 01:07 PM
go cheap on an i3 perhaps?
cpu and mobo and ram for around 250 maybe, maybe less depending on what you need.
you can sell your mobo cpu ram for around 150 or better maybe
or maybe wait till bulldozer but that could take another little while? if sb i3 unlocked were to come soon i may go for that
problem is though youd need a stronger cpu to drive that 580...hmm.....you know what? go for a 2500k build. b3 stepping mobos
are out it seems
Old February 28, 2011, 01:11 PM
Personally, your system is fast enough that I'd wait to see what Intel LGA 2011 and AMD Bulldozer platforms offer. In the short term, perhaps consider upgrading to an ssd and increasing ram.
Old March 1, 2011, 01:09 PM
Ok, so buying 1156 or 1366 at this point is a waste then?
I'll be keeping an eye on SB and IB to decide then I guess. Thanks for the advice.
Old March 1, 2011, 01:25 PM
Bond007's Avatar
Agree with above comments. Given your current setup I would bypass current AMD and also 1156/1366. Either go 2500k when SB is sorted out, see what BD brings or IB when that comes around (all depends how long you want to wait).
Old March 1, 2011, 03:14 PM
I would also wait and just get SB, for the money/performance you really can't beat it and well the only other option is to wait for Bulldozer and see what its capable of!
Comp1 (Mine) : ASUS P9X79 LE, 3960X, 16GB Corsair Vengence 1333, PNY 770 4GB, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : ASUS Sabertooth P67, i7 2700K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, EVGA 660, Corsair 1000HX, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Gigabyte 770, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 120
Old March 10, 2011, 09:55 AM
NCIX is having a sale, and I am close to pulling the trigger... still unsure.
Total comes to ~$700 for:
Reference ID:1034335017DelItem DescriptionIn StockPart #QTYPriceExt. Price Intel Core i7 2600K Quad Core Unlocked Hyperthreading Processor LGA1155 3.4GHZ Sandy Bridge 8MB
Usually ships in 1-2 business days. In Stock 57960 $309.99 $309.99 ASUS Sabertooth P67 P67 LGA1155 DDR3 2PCI-E16 3PCI-E1 1PCI Sandy Bridge B3 Motherboard
Usually ships in 1-2 business days. In Stock 59316 $209.99 $209.99 Add NCIX EXTENDED SERVICE PLAN What's this?</SPAN> No Service Plan NCIX.com 1 Year ESP Protection Plan - Only $39.99 NCIX.com 2 Year ESP Protection Plan - Only $49.99
G.SKILL Ripjaws X F3-12800CL9D-8GBXL 8GB 2X4GB DDR3-1600 CL9-9-9-24 Memory
Usually ships in 1-2 business days. In Stock 57953 $89.99 $89.99 Price Match request for the above item
Competitor's price: $87.46, source url: G.SKILL Ripjaws X F3-12800CL9D-8GBXL 8GB 2X4GB DDR3-1600 CL9-9-9-24 Memory - DirectCanada
Please read our Price Match terms & conditions for details.
$87.46$87.46 Shipping Estimate: Postal Code:
Free
Free Ground Shipping
What to do, what to do...
Old March 10, 2011, 10:01 AM
ZZLEE's Avatar
looks good
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old March 10, 2011, 10:26 AM
JD JD is offline
Looks like a solid choice of components. If you have the cash, I say go for it! It'll last you for a few years if you decide to overclock.
You might need some sort of mounting kit/adapter to use your TRUE on 1155.
Old March 10, 2011, 12:18 PM
id say save up for ivy bridge or bulldozer, your rig should be able to hold you down till then(its only a few more months) and that way youll have the high end cpus lol E-peen
