  #21 (permalink)
Old January 16, 2008, 03:22 PM
donimo's Avatar
lol@wowzas
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
  #22 (permalink)
Old January 16, 2008, 06:29 PM
misterlarry's Avatar
Default New Configuration
Hey guys, thanks a lot for all the input. After not building anything for a few years, its like coming out of a cave to try to catch up to tech levels. After giving everything that you have all said consideration, I went and priced out the following at DC. I've never tried OCing before, but I think I've got the right group of OC fanatics to help me on my way. Here's what I'm looking at now.
Antec P182 Atx Black Mid Tower Case 4X5.25 1X3.5 6X3.5INT No Ps Front Usb Audio Firewire
Gigabyte GA-P35-DS3L ATX LGA775 P35 1333FSB 1PCI-E16 3PCI-E1 3PCI SATA2 Sound GBLAN Motherboard
Intel Core 2 Duo E6600 Dual Core Processor LGA775 Conroe 2.40GHZ 1066FSB 4MB
Gigabyte GeForce 8800GTS 650MHZ 512MB 1.94GHZ DDR3 PCI-E Dual DVI-I HDCP HDTV Out
Crucial Ballistix Tracer DDR2 PC2-8500 2GB 2X1GB DDR2-1066 CL5-5-5-15 Dual Channel Memory Kit W/ LED
Thermalright ULTRA-120 Extreme 6 Heatpipe Cooler LGA775 Heatsink *Fan Not Included*
NMB-MAT (Panaflo) 120 mm Ball Bearing Fan 2500RPM 104CFM 41.5DBA, RPM Sensor
Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply Active PFC 120MM Fan
Pioneer DVR-212D Black DVD-RW 18X6X18 DVD+RW 18X8X18 Dl 10X Sata 2MB Oem Dvd Burner
All of this for $1275 including GST and shipping. Once again, I really appreciate everyone's input, and I would really like to hear what everyone thinks of this config.
  #23 (permalink)
Old January 16, 2008, 06:38 PM
Even better, it turns out to be $1228 because DC waived shipping charges.
  #24 (permalink)
Old January 16, 2008, 06:39 PM
magictorch's Avatar
Default switch the cpu
dont buy the E6600? did you mean Q6600 If your going dualcore get the E6750 from NCIX or DC..you can normally pick one up for under $190. The recent chips are great overclockers and you should be able to hit 3.6 fairly comfortably.
  #25 (permalink)
Old January 16, 2008, 06:45 PM
Your absolutely right. I did mean the Q6600. Must of slipped on the cut & paste.
  #26 (permalink)
Old January 16, 2008, 06:52 PM
donimo's Avatar
that panaflo is gonna be looooooud
but otherwise awesome build!
  #27 (permalink)
Old January 16, 2008, 07:03 PM
3.0charlie's Avatar
I second donimo here. Change that fan, it's just too loud. But otherwise, it is now a great build.
Hydro-Quebec is salivating...
  #28 (permalink)
Old January 16, 2008, 07:48 PM
Would any or all of these supply the required air flow for the cpu cooler? They are substantially more quiet.
Noctua NF-S12-800 120MM Ultra Quiet Cooling Fan 800RPM 59M3/H 8DBA Molex
Noctua NF-S12-1200 120MM Ultra Quiet Cooling Fan 1200RPM 81M3/H 17DBA Molex
Noctua NF-P12-1300 120MM Ultra Quiet Cooling Fan 1100-1300RPM 63-92M3/H 12.6-19.8DBA Molex
  #29 (permalink)
Old January 16, 2008, 07:55 PM
3.0charlie's Avatar
Third model will do just fine. I'm no expert, but a push-pull config with 2 fans may even be better.
Opinions on XFX 680i LT slugbug CPU's and Motherboards 14 December 21, 2007 04:29 PM
Anyone using an X-FI Elite Pro-opinions Ukonjack Audio 1 November 28, 2007 07:02 PM
Budget system Wiked CPU's and Motherboards 15 October 13, 2007 02:49 AM
Opinions on this as a good system? Vagabond142 CPU's and Motherboards 10 March 31, 2007 09:45 PM
Budget Gaming System Challenge BALISTX CPU's and Motherboards 21 March 13, 2007 10:30 AM
