-   -   i3 stock cooler ID (http://www.hardwarecanucks.com/forum/cpus-motherboards/40923-i3-stock-cooler-id.html)
botat29 February 19, 2011 07:58 AM
i3 stock cooler ID
HI everyone, I want to sell my i3 530 to a friend, but since it was on WC, I remove the stock cooler, I have 3 similars one and I donít know which one come with it, I know I can use anyone, But I will like to give the original one , can someone with a i3 530 ( or other i3) can check the Intel # of his cooler thanks
here the # of the cooler I have
E41759-002 ( this one have a copper base)
E33681-001
E18764-001
mkultra February 19, 2011 08:04 AM
what you listed seems to be a serialnumber, not a part number everybody's will be different.
i can say it's not the one with a copper base tho, mine is all alu
just make sure it has the right hole spacing
fan is rated @ 0.20amp if it can help
botat29 February 19, 2011 08:19 AM
thanks, I just take a coffee and found the problem, 2 are 775 :ph34r: and only the copper one is 1156, so it probably come from my i5-750 and the one of the i3-530 is just missing, I will install the copper one.
EDIT : just found the AL 1156 one, so I will put the AL one, in case I need the copper one for the i5 latter, thanks Mkultra it was a great help
_dangtx_ February 19, 2011 11:37 AM
e41997-002
.2a
nidec
dont think they shipped many with different coolers lately.
this one has no copper base, and its as slim or slimmer as
previous celly coolers.
