Old February 17, 2011, 08:30 PM
CTA's Avatar
CTA CTA is offline
well... it would be better if you tell us your computer specification... and what resolution do you prefer to use...
Old February 17, 2011, 08:31 PM
and which GPU, that's the question for games.
Old February 17, 2011, 08:34 PM
CTA's Avatar
CTA CTA is offline
again... depend on your resolution...
low resolution = gtx 560 ti and overclock it
high resolution = unlocked hd 6950 2gb
so you dont want to tell us your old computer... :?
Old February 17, 2011, 08:44 PM
It will be a single 1080p monitor, or possibly my two 720p monitors in eyefinity. My old computer is irrelevant and same with gpu, I'm more concerned with the CPU and if I will regret getting a i7 950 in a few months time. Gaming is the only reason for upgrading if you didn't pick that up already. Thanks for everyone who has responded :)
Old February 17, 2011, 08:46 PM
idk about you but i sure would, especially if you overclock
SB is the only cpu i would buy right now
Old February 17, 2011, 08:52 PM
good. go with the 1080p one now.
6950 2gb for gpu,dont look for anything less.
and of course 2500k. screw 1366 :p
or dont buy anything till dozer hits? but that will be a little while.
Old February 17, 2011, 10:26 PM
Just make sure that if you buy the 2500k that your mobo is covered under the replacement/repair plan!! There is a limited time window where you can get your chipset fixed... if you buy too late they aren't covering you!
Yep, otherwise 2500k all the way if you will overclock!
Old February 17, 2011, 10:32 PM
CTA's Avatar
CTA CTA is offline
yeah i agreed with dantgx about amd bulldozer (or new i7)... just a few months away...
Need help with new 2500K system AKY Overclocking, Tweaking and Benchmarking 12 February 16, 2011 01:06 PM
Intel Sandy Bridge High C/P Combo-Core i5-2500K with GIGABYTE P67A-UD3R OC Guide windwithme Member Reviews 5 February 10, 2011 02:38 PM
2500K + P8P67 Pro Overclocking Realityshift Overclocking, Tweaking and Benchmarking 0 January 24, 2011 11:20 AM
No gain from Radeon 4870 + Core i5 2500k folding frontier204 HardwareCanucks F@H Team 3 January 18, 2011 05:56 PM
AKG? Best Coolers for Sandy Bridge 2500K-2600K OC Delavan Air Cooling 12 January 10, 2011 04:33 PM
