Old February 7, 2011, 10:15 AM
N.E.A's Avatar
Default should i go for sandy bridge now or wait
hey guys, in my country the stores say i can buy the board and when the new ones come i can change my board with a refined one .. my questions to you are :
1.Should i go for it now or wait ? since going for it now will be some kind of a waste, keep in mind that my build only uses two sata ports.
2. In case i choose to go for it, does changing the board mean installing new windows or can i do some kind of a backup to restore my settings and configurations ?
thanks in advance and for your time.
Old February 7, 2011, 10:20 AM
botat29's Avatar
With Windows 7 you can easily change a board, especially the exact same model, Windows will reboot and adjust, but you can expect to have to give a call to Microsoft to reactivate it, should not be a problem too. But if I was you, I will wait, you never know if you will not need those extra port 1 day.
Old February 7, 2011, 10:22 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Yes true, you wont have to reinstall windows but MS will see it as hardware change so you have to call in and reactivate. If you need a system up and running now go for it, you will be fine with the sata6 ports. Just remember that RMA will take several weeks so you will be without a board for a while.
Originally Posted by botat29 View Post
With Windows 7 you can easily change a board, especially the exact same model, buy you can expect to have to give a call to Microsoft to reactivate it, should not be a problem too. But if I was I will wait.
Old February 7, 2011, 11:04 AM
N.E.A's Avatar
thanks for the effort guys but, when will the new boards come out? I need the pc before 5/3/2011
Old February 7, 2011, 11:14 AM
Eldonko's Avatar
April probably
Old February 7, 2011, 11:26 AM
N.E.A's Avatar
Originally Posted by Eldonko View Post
April probably
if this is true then i will build the pc in march since i can not afford to wait that long..i hope they finish it quickly
Old February 7, 2011, 12:16 PM
just buy now and use not the one bad port(s)
unless theres other stuff going with time with this chipset revision, you should be fine :)
Old February 7, 2011, 01:25 PM
Only if you can find a shady place that is willing to sell P67 boards...
heatware
Old February 7, 2011, 01:26 PM
Eldonko's Avatar
OP says he can buy P67 in his country. Im sure there are tons of places that dont care about the recall.
Old February 7, 2011, 01:41 PM
Most places seem to be still selling the boards if you ask them in person and they get the chance to explain to you the "issue".
It's not a loss for them to do so, and they all have chips to move as well, so it makes sense.
Sandy bridge notebooks? dustin1706 Mobile Computing 13 January 24, 2011 07:34 PM
My Sandy Bridge Build Eluder New Builds 24 January 17, 2011 06:42 PM
1st ever build now or wait for sandy bridge? tl9015 New Builds 25 December 2, 2010 01:34 PM
Sandy Bridge tested Bond007 Reviews & Articles from the Web 7 August 28, 2010 11:32 AM
what is intel Sandy Bridge? kuziwk Rumor Mill 18 February 26, 2010 06:40 PM
