Old February 1, 2011, 05:57 PM
writhen's Avatar
Default Cougar Point recall has screwed me, need advice.
As a couple of you may know I posted a thread a couple of days back asking for opinions on sandy mobos. So I drove to memory yesterday to buy the Gigabyte UD7 and the guy brings mine out from the back room (had it on hold) rings it in and goes "So its 311.xx Visa or Debit?....Oh crap, I don't think I can sell these".
He goes and gets his manager, at this point I figured I was screwed. Manager comes back and says none of the Cougar Point boards will be sold anymore until Intel figures out what to do. From everything I've read on the net, looks like everyone has to make new mobos which will probably only be released by April.
This leaves me between a rock and a hard place. I have ALL my other components bought (this was to be my first xfire+eyefinity build) and no motherboard to connect them to. This is the only desktop I have right now (need one for work and school, not just play) and currently I'm forced to work off my laptop.
So my options are:
1) keep all the parts I bought new (haf-x, 8gb Gskill, 2500k, 3x s243hl's, dual 6870's, ax850 gold, nhd14, g9x/g19 combo) on a shelf somewhere till intel figures their crap out. This leaves me with no computer for probably 3 months, and parts that are depreciating in value without being used. Even then, the boards will probably be in high demand by april and sold out everywhere.
2) Sell the 2500k at a loss and go AMD? Except bulldozer is coming out (god knows when in reality even though they say Q2) and AMD has nothing that can even come close to sandy.
My question is: What would you do in my situation?
I'm thinking of a downgrade to 1090T BE or a 1366 build (only be able to do a i7 950 as the others are way out of my league)
Old February 1, 2011, 06:00 PM
You don't have option 3) Return the 2500k?
Old February 1, 2011, 06:01 PM
chrisk's Avatar
Folding Captain
That sucks.
Canada Computers seems to be selling boards...hit them up and order online before they change their minds.
Fold for team #54196
Old February 1, 2011, 06:02 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
I would wait personally.
Old February 1, 2011, 06:04 PM
chrisk's Avatar
Folding Captain
If you don't want to wait, CC has stock of that board:
Gigabyte GA-P67A-UD7 Socket 1155 Intel P67 Chipset CrossfireX/3-Way SLI Dual-Channel DDR3 2133/1866/1600/1333/1066Mhz 2x PCI-Express 2.0 x16 Dual GigaLAN 7.1-CH HD Audio 4x SATA 6.0Gb/s 2x SATA 6.0Gb/s 4x SATA 3.0Gb/s 10x USB 3.0/2.0 IEEE 1394a ATX |
That being said, are you happy getting a CP based board now? Would you be willing to RMA later on if you want it replaced? Will be hard to sell if you decide to do so later on.
Old February 1, 2011, 06:08 PM
writhen's Avatar
Thanks for the Canada Computers link guys, I placed my order with them but they'll probably cancel it. Can't see how they wouldn't. Can't return the 2500k as it's passed the 7 day return. I only have 3 devices, dvdrw drive, ssd, and hdd. with 4 6Gbps ports I should be fine right? From what I've read its only the 3Gbps ports over time...
Old February 1, 2011, 06:25 PM
MacJunky's Avatar
You could just get a SATA card...
Old February 1, 2011, 06:32 PM
My suggestion is see if you can sell the 2500K on eBay or something.
Then pick up a cheap P55+i3 combo for now and overclock it to 4.2 GHz+.. that should tide you over for the next couple of months imo.
heatware
Old February 1, 2011, 06:56 PM
Blu's Avatar
Blu Blu is offline
That should be able to do you a couple years, I doubt a upgrade would be needed unless you want to grow your e-penis a little bigger.
Old February 1, 2011, 06:58 PM
not only that, but you may like clarkdale so much you'll stick with it till 2011 hits the streets or later~!
COUGAR SX700 PSU whited Power Supplies 6 January 8, 2011 03:27 PM
NVIDIA 196.75 Driver Recall - Overheating Problems Cause GPU Deaths FiXT Press Releases & Tech News 29 March 14, 2010 07:08 PM
am i screwed? BobbyLou Off Topic 19 March 2, 2010 10:28 PM
My keyboard is screwed!!! jcmaz Off Topic 9 June 30, 2009 07:56 PM
Swiftech GT200 ADAPTER KIT RECALL sswilson Water Cooling 0 December 9, 2008 09:50 AM
