Old January 10, 2008, 06:55 PM
Default Advice on mobo needed badly
Ordered a 780i (when it was in stock) and now the place I ordered from has stopped replying to most customer service requests/questions and I am presuming they cannot supply.
Anyhoo - I have a Q6600, Enermax PSU, 4 GB CB Tracer PC8500 1066 RAM and an 8800 Ultra looking for a mobo. I may SLI in the future so would like that option but would also consider non SLI boards. Primarily for gaming.
What mobo do you experts suggest that will utilize what I have above?
Thanks
9V9
Old January 10, 2008, 07:08 PM
Thanks
9V9
You only have 680i and 780i for SLI and neither would I recommend at all.
For now the P35s unfortunately are the way to go as 780i is way to new and you don't know what type of bugs or what can happen and the 680i well its just junk.
Old January 10, 2008, 07:36 PM
Thanks. Any specific P35 you would recomend?
9V9
Old January 10, 2008, 11:52 PM
I just ordered the Abit IP35 Pro, looks great, lots of room on it.
Old January 11, 2008, 12:49 AM
reaverclan's Avatar
i have a GA-P35-DS3L and it rules if u only want a stable system and to over clock a little or a lot, i only did a little cause i only need a little:) and it sells for only like $99
The-Jew/Xfire=reaverclan/My Photobucket
mobo:GA-P35-DS3L Rev.2(BIOS F7)
os:
Win7 Pro x64/Ubuntu 9.10 x64
cpu:Q6600@3040.0GHz
cooling:
OCZ Vendetta 2 ram:4GB(4x1GB) Corsair XMS2 800 4-4-4-12
gpu:EVGA GTX280 SSC hdd:Seagate 1024GB psu:HX620w
disp:
Vizio 1080p TV (32'') sound:X-Fi Xtreme Gamer case:Antec 1200
Old January 11, 2008, 05:35 AM
Thanks guys.
9V9
Old January 11, 2008, 10:46 AM
ebdoradz's Avatar
GigaByte offer a few version of the GA-P35-DS3, if you need raid then take the DS3R
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 5112mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
ABIT KT7A-RAID / AMD Athlon XP 1800+ @ stock/ 2*256mb PC133/ Geforce 4 mx440 / 250W PSU / Maxtor 20GB
Old January 11, 2008, 09:18 PM
Kinda depends on what you're looking for?
eSATA matter to you?
Dual gigabit ethernet?
Number of SATA ports?
Overclockability?
Price?
That all being said, i too would strongly urge against the overpriced crapsets nVidia has put out, & since SLI & CF are largely a waste of money, i wouldn't worry about that.
P35 is indeed the best bang/buck option right.
Asus P5K series is nice.
Gigabyte DS3 series also.
Abit IP35 is another great option.
All those OC quite well, even the vanilla DS3L & P5K.
Old January 11, 2008, 10:23 PM
Cptn Vortex's Avatar
I did churn out better numbers with my P35 board then my 680i yes. The 680i has been working strong for me though, and I don't have any issues with it. SLI as well.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Mobo advice for new build D1rtyB1rd CPU's and Motherboards 26 March 6, 2008 01:23 PM
Budget video card advice needed please. Mumbly Video Cards 9 January 17, 2008 04:59 AM
What kind of video card is needed for this LCD TV neurobashing Display Units 1 August 13, 2007 02:02 PM
What kind of video card is needed for this LCD TV neurobashing Video Cards 3 August 10, 2007 02:56 PM
case needed Jim Troubleshooting 9 May 8, 2007 01:43 PM
