Old January 27, 2011, 07:31 PM
Default H67 Motherboard?
Which motherboard should I get out of these two.
Buy Gigabyte [GA-H67M-D2] Gigabyte H67M-D2 mATX LGA1155 H67 DDR3 2PCI-E16 2PCI-E1 CrossFireX SATA3 Motherboard
Buy ASUS [P8H67-M LX] ASUS P8H67-M LX mATX H67 LGA1155 2PCI-E16 PCI-E1 PCI HDMI VGA Sandy Bridge Motherboard
I like the aesthetics of the ASUS beter but it costs slightly more. Is one better than the other in any way?
Old January 27, 2011, 07:33 PM
Arinoth's Avatar
The gigabyte one will support crossfire where as the asus one you can only ever run one card in it.
Old January 27, 2011, 07:35 PM
botat29's Avatar
from de description of the gigabyte : "The PCIEX16 slot operates at up to x4 mode when ATI CrossFireX™ is enabled."
Old January 27, 2011, 07:38 PM
Crossfire does not matter as I will only ever use the on-board graphics.
Old January 27, 2011, 08:20 PM
Arinoth's Avatar
I ran dual 6870s on it and i never really noticed a frame rate hit (didn't fraps, used my eyes and same settings when on an x16 x16 board).
OP: if thats the case then there is no real difference for you and whatever looks better to you or best fits your budget.
Old January 28, 2011, 12:16 AM
I personally prefer Gigabyte over Asus when buying a lower end board. Asus firmware/BIOS has never been that great at launch, especially on the low end and sometimes questionable on the higher end. If you can wait for a revision though, it's usually fine.
Old January 28, 2011, 07:37 AM
I prefer ASUS and they certainly have the lion's share of the market. There is a reason for that....the consumer has decided that ASUS is the one. Perception is reality. When one considers the return rate of mobos and the fact that less ASUS come back, IMO, there is no other choice that I would feel comfortable with.
Caveat Emptor
Old January 28, 2011, 11:09 AM
I noticed that the ASUS has an 8 pin CPU power connection but the Gigabyte only has a 4 pin. Does this make any difference?
Old January 28, 2011, 11:13 AM
Not really, especially if you're not putting in a video card or two.
"What is the colour when black is burnt ?" - Neil Young
Old January 28, 2011, 11:21 AM
botat29's Avatar
Originally Posted by ilya View Post
.... Asus firmware/BIOS ........
speaking of the BIOS.... Asus use the new EFI, so now it's graphical and We use the mouse.
[WTB] S775 Motherboard and I7 920/930 cpu + x58 motherboard Table21 Buy/Sell & Trade 6 May 22, 2010 10:23 PM
New motherboard Jonwall CPU's and Motherboards 5 October 23, 2008 04:37 PM
Motherboard help maurier Troubleshooting 9 May 22, 2008 12:21 PM
New motherboard Infiniti CPU's and Motherboards 6 April 30, 2008 06:55 PM
Looking for a new motherboard JD CPU's and Motherboards 1 December 30, 2007 01:14 AM
