Old January 13, 2011, 01:02 PM
Slaughter's Avatar
Default Need Advice - New Motherboard And/or Ram?
Hello!
Just looking for some advice...
My DDR2 has recently died on me and I've been offered either $80 cash or the following DDR3 replacemement:
OCZ DDR3 PC3-10666 Platinum Low Voltage Dual Channel OCZ Technology
This memory is not the kind of specs I would be looking to go for in DDR3 nor am I really comfortable staying with OCZ based on their recent announcement that they will be dropping out of the memory business.
Currently I have a 965BE and a Gigabyte MA785G-UD3H motherboard. Where I need help is deciding whether I am best to use the $80 and buy some more DDR2 or use the opportunity to upgrade my motherboard and move into DDR3.
If I were to upgrade to a new motherboard, what do you recommend?
I do not intend to run Tri/Quad PCIe's so that is not a determining factor for me. I would like to maximize performance however.
If you need anymore information, please do not hesitate to ask! I do check back in quite often... (a few times an hour anyways) LoL.
Cheers!
Slaughter
Old January 13, 2011, 03:07 PM
get the money and grab some cheap ram, couple gigs to get you to the bd releases :) or go sb now? :)
Old January 13, 2011, 03:11 PM
I would take the cash and use the opportunity to move to a new mobo. You can buy a 4GB DDR3 set these days for $45.
Old January 13, 2011, 05:14 PM
Slaughter's Avatar
Should have mentioned that I don't plan on upgrading my CPU.
Advice on motherboard shanji CPU's and Motherboards 5 February 16, 2010 07:06 PM
ram advice bmfmass RAM 0 December 15, 2009 07:04 PM
New Mobo--need ram advice Surk RAM 2 December 8, 2009 08:44 AM
Looking for advice on RAM upgrade Arundor RAM 4 November 22, 2008 06:21 PM
Advice on Ram upgrade Sniper RAM 8 October 25, 2008 10:28 AM
