Old January 11, 2011, 02:24 AM
Blu's Avatar
Blu Blu is offline
Default What to do
I made a bad mistake...The graphics card for my HTPC is not going to fit in the PCI-E16 slot as well as my extra sata port connection card (I need it for 3 ports) Now my question to you guys here is...
Do I keep my old board and hope it can load and play ps1 imports and all emulators and some new end games off the board (880gma) or I can toss on a GTS210 on this as well. Or option two,
Buy this motherboard,
NCIX.com - Buy Gigabyte GA-880GA-UD3H AMD880G ATX AM3 DDR3 3PCIE 2-WAY CrossFireX GBLAN SATA3 USB3.0 Motherboard - GA-880GA-UD3H In Canada.
Or this board,
NCIX.com - Buy Gigabyte 890GPA-UD3H 890GX AM3 ATX DDR3 2PCI-E 2PCI SATA3 USB3.0 HDMI GBLAN CrossFireX Motherboard - GA-890GPA-UD3H In Canada.
It's got all the sata ports I need on it so I won't need to rely on a card plus my graphics card and sound and fan card will all fit perfectly fine but then I'll have a spare motherboard laying around as well as a sata card.
What would you do in this position?
Old January 11, 2011, 03:01 AM
before you snap and order, broaden our view a bit, with more info or perhaps a piccie of the whole shebang? :)
in sig or drop down menu specs usually help a lot.
Old January 11, 2011, 02:59 PM
Blu's Avatar
Blu Blu is offline
The HTPC so far has the following,
amd 550 dual core cpu
mobo - to pick here
ram - corsair 4GB sticks x2
psu - seasonic 400watt 80 plus
hard drive - kingston 64GB ssd
storage drives - 6 2TB WD Ears drives
Graphics card is either a 210GT or a 5670 if I get the space for it.
Thats pretty much the specs of it, plus alot of cool little nick nacks to go with it :)
Old January 11, 2011, 03:20 PM
ok,go with the cheaper solution that will have you running.
Old January 11, 2011, 03:56 PM
Arinoth's Avatar
You do know if you get good onboard, aka the HD4200 series that it has no issues with any kind of video playback upto and including 1080p
Here I am: here I remain
Old January 11, 2011, 04:23 PM
headsh0t's Avatar
So what is your problem? Your sata card is PCI-e? You could always test out the onboard graphics with your PS1 Emulators and see if it works, and if not you could throw your video card back in and get a PCI Sata card? That would be the better option besides buying a new board...
Old January 11, 2011, 07:58 PM
Blu's Avatar
Blu Blu is offline
I ended up just buying a new board, the problem was I never had the room for the graphics card + the sata card so I ended up with this,
It will get the job done and gives me room for a extra pci x1 slot which I need for sound or tv tuner card anyways....so I'll put the sound card first, then video card, then tv tuner card then pci fan card. should work out nicely.
