Old January 3, 2011, 03:45 PM
Blu's Avatar
Blu Blu is offline
Default Are these the mosfet's?
I've never done any cooling on mosfet's before and wanted to make sure I had the right thing in mind before I do it,
Is it what I have highlighted here with the red oval? I was planning on putting these on them to keep them nice and cool,
Swiftech MC21 Aluminum MOSFET Heatsinks - 4 pack - FrozenCPU.com
So tell me if this is a good idea or not...I sorta want to make my HTPC as custom as can be :D
Old January 3, 2011, 04:21 PM
gingerbee's Avatar
NCIX.com - Buy Enzotech BMR-C1 Forged Copper BGA Memory Heatsinks for Video Card Memory 8 Pack W/ Thermaltape - BMR-C1 In Canada.
these are better but i guess you can use those too a heat sinks a heat sink besides the fact these are copper much better thermal conductivity
perfect size too these are he he Enzontech Mosfet Heatsink - MOS-C1
if you can find them local i have always just cut the other ones up
Old January 3, 2011, 04:27 PM
Blu's Avatar
Blu Blu is offline
So those are the mosfets that I have circled? Would these work just as well to keep up with the color theme :D?
NCIX.com - Buy Zalman ZM-RHS1 Video Card RAM Sink 8 Pack W/ Thermal Tape - ZM-RHS1 In Canada.
I was also thinking of replacing my northbridge but I've heard it's a little to large so I would need some thermal glue which doesn't come off easy.
Old January 3, 2011, 04:28 PM
Enzos stick better than the Zalmans
Old January 3, 2011, 04:32 PM
Blu's Avatar
Blu Blu is offline
Also these I just remove some covering of the tape on the bottom and stick to the board right?
Old January 3, 2011, 04:37 PM
im not sure either of you have answered dudes question, lol
Microcool Silver MOSFET Chipsink
so yup,thats a mosfet.
Old January 3, 2011, 04:48 PM
gingerbee's Avatar
yup and yup.
edit i figured he knew where they where since he had them pointed too but after rereading your right and ya the enzo's stick better
Old January 3, 2011, 04:49 PM
sswilson's Avatar
I'd recommend the enzos because of personal experience with the adhesive of the thermal tape. The copper is also easy to cut with a dremmel tool in order to get just the right size.
The only thing to keep in mind is that the thermal tape isn't neccesarily non-conductive, so you want to be absolutely sure that you're not making contact with any of the soldered points.
Old January 3, 2011, 04:54 PM
and if theyre going to be close to each other or other conductive stuff, get a thick piece of paper between them that youll be able to easily slide in and out, just to make sure.
Old January 3, 2011, 05:13 PM
Blu's Avatar
Blu Blu is offline
I think I might just say no to the mosfet coolers since this is just going to be a HTPC and I'm not really overclocking just going to try and unlock the extra cores so I'm hoping it doesn't run to hot...
[WTB] SB + MOSFET Blocks Mattu Buy/Sell & Trade 5 April 26, 2010 09:18 AM
installing mosfet blocks. kyle_L Water Cooling 7 February 21, 2009 08:24 PM
mosfet block out or in the loop? TAOTAO161 Water Cooling 1 February 15, 2009 04:02 PM
[WTB] P5N32-E SLI NB/SB Mosfet Heatsinks TerenceJ Buy/Sell & Trade 2 December 25, 2008 09:17 PM
[WTB] Copper NB or mosfet HS Varroa Buy/Sell & Trade 3 November 30, 2008 07:32 PM
