Old December 20, 2010, 05:53 PM
Default OCing a Phenom II X3 740 BE Unlocked
I'm just wondering if it's safe to pump more voltage in this thing without turning CnQ off? I see a lot of OCing with X2 555 BE's, 955BE's and 1090T's but not too much with these tri's. I don't need the maximum possible OC and would like to conserve energy where possible since I don't game all that much.
I unlocked it and ran Prime 95 for 6 hours at 3600mhz+ already with CnQ on and left voltages on Auto. Seems to be hitting 1.40 according to CPU-Z under load. What are other people getting with these chips? All in all i'm pretty pleased with this, 600mhz and a free core isn't too shabby!
EDIT: Oh and it's cooled by a Hyper 212+ in a case with quite a few fans (HAF 912)
Old December 20, 2010, 05:56 PM
geokilla's Avatar
First off, when you overclock you should have Cool n Quiet turned off. Turn it back on after the overclock if you wish, though you should be folding instead :P
Second, the max voltage I would put on air cooling is 1.45 to 1.5Vcore. Anymore and you're asking for trouble.
Third. Use manual voltages when overclocking! Do not use anything auto!
Old December 20, 2010, 09:05 PM
Done, done and done. Just wondering on the first point though, why is it necessary to turn it off when you first OC if i'm going to run Prime 95 immediately anyways?
Old December 20, 2010, 09:16 PM
cool n q plays with the voltage, multi's. a stable oc is one you can fully control. its possible that when cnq kicks in for it to become unstable, or weird things like temporary freezes due to insufficient juice to the cpu and such.
How much is my stuff worth Core Unlocked Phenom 2 X2 Setup? kingnubian Off Topic 2 April 5, 2010 03:51 AM
wPrime with unlocked Phenom II and HWbot ebdoradz Overclocking, Tweaking and Benchmarking 2 August 31, 2009 05:13 PM
Phenom II X2 550BE (UNLOCKED) punk_zappa Overclocking, Tweaking and Benchmarking 75 August 29, 2009 11:45 PM
A Nice OCing Mobo for a Phenom II 955 AmuseMe CPU's and Motherboards 7 July 16, 2009 05:35 PM
AMD prepares its Phenom FX, Phenom X4 and Phenom X2 lineups Babrbarossa Press Releases & Tech News 1 May 4, 2007 07:38 AM
