Old December 17, 2010, 11:26 PM
Default BEST i7 970 BATCH - 3018A860
I read through lots of threads here, and on GURU3D and Xtremesystem and I think i hit the jackpot with this batch of i7 970. They are absolutely amazing!. I have easily hit 4.0ghz (167 x 24) and DDR3-2000 T1 cas 9 with very minimum voltage.
vcore: 1.240
vtt/imc: 1.2
dram: 1.5
The temperature is absolutely amazing. with room temperature at 21.5C, I idle at 17-22 degrees and load at 53-58 degrees! Sorry for the bragging (sharing), but I am loving this chip.
Uploaded with ImageShack.us
Old December 18, 2010, 02:31 AM
How do you idle at 17-22 when the room is 21.5? What kind of cooler are you using...
Old December 18, 2010, 05:05 AM
matsta31's Avatar
look at his desktop picture : ICE ! He must get 3 degrees cooler because of it !
Sold hardware again.....
Currently using WHS hardware....
Old December 18, 2010, 05:12 AM
Haha yupyup! My cooler is zalman cnps9900max and case is NZXT Phantom
Old December 18, 2010, 06:02 AM
As promised here is the NZXT phantom:
Old December 18, 2010, 06:26 AM
gingerbee's Avatar
well then let me be the first to burst your bubble of joy on air it is a physical impossibility to get below ambient room temp hell even on water once your loop heats up it almost impossible so idling at those temps is just wrong. that being said the diode for temp monitoring is set to be 100% accurate at max tdp to have safe tmfunction and when it comes down to it load temp is all that matters but great load temps and great overclock nice chip
Old December 18, 2010, 07:41 AM
JD JD is offline
Maybe he has a cold draft coming in through the window to the left of the PC ;)
Old December 18, 2010, 08:05 AM
gingerbee's Avatar
lmao still great overclock
Old December 18, 2010, 09:12 AM
Sagath's Avatar
I have the same batch. You got a lucky chip. My VID is 1.3v, and I need 1.3625 to hit 4.1 stable. Nice Lotto tho.
Originally Posted by Lpfan4ever View Post
AKG shot the hamsters, and then Perineum drove his Mustang with summer tires into the server.
Old December 18, 2010, 09:20 AM
bojangles's Avatar
Why is hyperthreading not enabled? Try cooling that with your cooler.
But at the same time I don't believe those temps...even on 32 nm. Someone prove me wrong here.
Batch files. encorp O/S's, Drivers & General Software 33 October 8, 2010 11:47 AM
Anyone had this i7 930 batch yet? Jelah Overclocking, Tweaking and Benchmarking 13 August 9, 2010 05:17 PM
Core I7 Batch# Saterial CPU's and Motherboards 4 July 3, 2009 09:52 AM
batch numbers Rapid-X Overclocking, Tweaking and Benchmarking 8 May 12, 2008 10:29 PM
Intel Batch Codes enaberif CPU's and Motherboards 2 February 14, 2008 10:56 AM
