Old December 18, 2010, 10:36 AM
HT useless. I had it on before and it raised temp 5-8 degrees depending on which core. What is there not to believe? It is running maximum stress test and that's the temperature i'm getting?
Old December 18, 2010, 10:41 AM
Arinoth's Avatar
Its less impressive overclocking without HT on with the 1366s, thats why you are getting such good temperatures.
Here I am: here I remain
Old December 18, 2010, 10:46 AM
chrisk's Avatar
Folding Captain
I believe the temps he has posted. No HT, and running at 2GHZ from the screenies I have seen here in the thread. the only thing I doubt might be the ambient temps, but that is most likely just an honest error.
Fold for team #54196
Old December 18, 2010, 11:57 AM
gingerbee's Avatar
I believe your temps at max stress with ht off but i missed the whole ht off it's kinda pointless with it off if you got it use. but like i said before there's no way your idle temps are just wrong but that is also normal from a lot of chips the diode is set for max tdp turn on ht and see what you can get even if it goes up 10c your still fine and now you have 12 threads
oh and ht is not useless when you multi-app a lot it does make the difference get a digital temp gauge and an ir temp gauge these will let you know for sure. still like said before wicked overclock for 1.24vcore
Old December 18, 2010, 12:06 PM
rjbarker's Avatar
I have the same batch. You got a lucky chip. My VID is 1.3v, and I need 1.3625 to hit 4.1 stable. Nice Lotto tho.
Yep I need 1.386v on my 980X at 4.13 Ghz.... ;(
HT "off" explains both his low Temps and stable OC at that voltage....turn it "on" and its a different story altogether I bet...why "cripple" a 970 or 980X by turning it off ?
Firestrike Extreme: 21.452
MARK 11: 32.530
Old December 20, 2010, 07:39 PM
Blu's Avatar
Blu Blu is offline
sweet overclock, I wonder if anyone will even consider buying 970's when the sandy bridge comes out.
Old December 20, 2010, 08:11 PM
lowfat's Avatar
LGA1155 CPU's are still only quad cores. If you have applications that take advantage of multiple threads (i.e. foldling@home) then hexacores will still be a better buy.
Mael
Big Lian Li
Forever Alone
Old December 23, 2010, 06:32 PM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
Just to reiterate something, idle temps are generally reported wrong since the integrated sensors aren't calibrated with low temperatures in mind. I don't know the specifics
Batch files. encorp O/S's, Drivers & General Software 33 October 8, 2010 11:47 AM
Anyone had this i7 930 batch yet? Jelah Overclocking, Tweaking and Benchmarking 13 August 9, 2010 05:17 PM
Core I7 Batch# Saterial CPU's and Motherboards 4 July 3, 2009 09:52 AM
batch numbers Rapid-X Overclocking, Tweaking and Benchmarking 8 May 12, 2008 10:29 PM
Intel Batch Codes enaberif CPU's and Motherboards 2 February 14, 2008 11:56 AM
