Old January 2, 2008, 10:51 AM
Default XP pro or home?
I'm not sure which one to run. I was going to run home, but I just read that home doesn't have support for multi processors. Does this mean it won't use the 2nd core on a C2D ?
By the way, my new system is on the way, thanks for your help.
Case - Coolermaster CAC-T05 Centurion 5 Aluminum ATX Tower Case
DVD - LG GSA-H55N Black DVD+RW 20X8X16 DVD-RW 20X6X16 INT IDE 2MB OEM DVD Writer W/ SW
CPU - Intel Core 2 Duo E6750 Dual Core Processor LGA775 Conroe 2.66GHZ 1333FSB 4MB Retail
Mobo - Gigabyte GA-P35-DS3L ATX LGA775 P35 1333FSB 1PCI-E16 3PCI-E1 3PCI SATA2 Sound GBLAN Motherboard
HDD - Seagate Barracuda 7200.10 250GB SATA2 8.5MS 7200RPM 16MB Cache Hard Drive 5YR MFR Warranty
PSU - Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply Active PFC 120MM Fan
GPU - Galaxy GeForce 8800GTS 650MHZ 512MB 1.94GHZ DDR3 PCI-E Dual DVI-I HDCP HDTV Out OEM Video Card1
Old January 2, 2008, 10:53 AM
No two CPUs. As in two physical dies
Old January 2, 2008, 11:19 AM
oh ok, thank you
Old January 2, 2008, 12:37 PM
Only need home; no need for Pro and Home is cheaper.
Old January 2, 2008, 06:01 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Yeah home is fine for a regular user.
Old January 2, 2008, 10:39 PM
sswilson's Avatar
I believe the only things that Pro offers over home are mostly related to being able to log into an internal domain on an intranet or something silly like that.....
Old January 2, 2008, 10:55 PM
mr_plow_king's Avatar
the remote desktop host is only available with XP pro. That page should help you choose :
Windows XP Home Edition Comparison Guide
Old January 3, 2008, 12:16 PM
Jack Rabbit's Avatar
Home does not support more than one monitor. For that alone I went "pro".
Old January 3, 2008, 12:20 PM
Please don't spread such garbage, XP Home can work fine with Dual Monitors just as XP Pro can.
XP Pro has a few more networking options for domains which is the only real difference.
Old January 3, 2008, 01:11 PM
Thund3rball's Avatar
If you are running a home network as I am, Home can give you a bit of trouble with setup. I had a heck of a time getting my Lappy (XP Home), PC (XP Home) and Storage (Win 2000) to all see each other. In Pro the network configurations options are much better. Other than that I find Home to be just dandy :)
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Folding @ Home F.A.Q. Supergrover HardwareCanucks F@H Team 229 May 15, 2010 08:24 PM
Home Theatres, Whos Got One ? lcdguy Off Topic 11 May 10, 2007 12:12 PM
Home Security Shadowed Reviews & Articles from the Web 0 April 23, 2007 01:05 PM
Microsoft Home Server D1GGY Networking 2 March 7, 2007 07:58 PM
