Old December 10, 2010, 02:39 PM
Default How many fans per motherboard header?
I am currently using a Rampage 3 Extreme. I have a few Gelid Silent 12 fans that draw .18A @ 12 V. I plan on making a 3 way fan splitter so I can connect the three top fans of my case to the same header. Out of my R3E manual:
The fan connectors support cooling fans of 350mA-2000mA (24 W max.) or a total of 1A-7A (84W max.) at +12V.
If someone could walk me through the math used to calculate my answer, that would be much appreciated.
Old December 10, 2010, 02:45 PM
Gelid's are fairly low power fans, you definitely shouldn't have any problems.
Doing the math, you can realistically put 10+ fans on a daisy chain to that header assuming the motherboard specs are correct.
0.18Ax12V=2.16W
Old December 10, 2010, 10:15 PM
while it can take quite a bit of amperage, i would stick to one low to medium power fan. get a controller, if you have that many :)
Old December 30, 2010, 11:52 PM
I would susggest using this.
Sunbeam RHK-EX-BA Rheobus-Extreme
I use a few of these on different computers and you can run many fan's from it.
Old December 31, 2010, 12:32 AM
I'd like to see how this goes aswell, as I've been wondering if I can do the same in the future. Since I'm using the same fans!
Old September 1, 2012, 05:15 PM
Just chain them all right up to the psu? Do fans still come with 4pin these days? my case fans are like 3-4years old.
Old September 3, 2012, 09:46 AM
I think op might be dead from the fire.
[ or a total of 1A-7A (84W max.) at +12V.]
Old September 3, 2012, 12:13 PM
Adzsask's Avatar
I ran a 3300RPM delta server fan off of an R2gene for over a year so no worries on 3 geild's.
Old September 3, 2012, 02:48 PM
ZZLEE's Avatar
Canada Computers | Cooling | GELID PWM 1-to-4 Splitter (CA-PWM-03) -- connect up to 4 PWM fans to CPU socket
try this pwm on mb header 4 fans powered by molex
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old September 3, 2012, 03:16 PM
Sagath's Avatar
The math doesnt add up. Its either 2A max@12v (24w), or its 7A max@12v (84w), unless you're misreading the book, and the 1-7A part is referring to the combined fan headers output power. Which I think is the more likely case.
Assuming the latter, and its a single/combined spec, if your fans are drawing 180mA, you could hook up 11 based on the first numbers given, but that many fans in parallel are gonna drop the voltage a bit, creating a strain, plus start up spin draw is always higher then running speed draw.
I personally wouldnt go higher then 3-5, and see what your bios says your fan speeds (and voltage if it has it) are at, and make a call from there. Or, just skip that and get an aftermarket header.
Originally Posted by Lpfan4ever View Post
AKG shot the hamsters, and then Perineum drove his Mustang with summer tires into the server.
Asus Shows Off P7P55/USB3 Motherboard with USB3.0 Header FiXT Press Releases & Tech News 0 July 16, 2010 11:22 AM
2 fans on 1 header ITaoI Air Cooling 1 August 26, 2009 06:50 PM
how many fans can I run off of motherboard cpu fan plugin Shadowmeph CPU's and Motherboards 3 August 5, 2009 01:17 PM
Connect case fans to the motherboard? Dogger1 Air Cooling 8 February 28, 2009 12:32 AM
