<~----> How many fans per motherboard header? - Page 2 - Hardware Canucks
Old September 3, 2012, 05:08 PM
NyteOwl's Avatar
Being a conservative sort I put one fan on one header. Placing them in parallel will not only change the current draw but also alter the fans' speed (unless you use a controller)
Obsolescence is just a lack of imagination.
Asus Shows Off P7P55/USB3 Motherboard with USB3.0 Header FiXT Press Releases & Tech News 0 July 16, 2010 11:22 AM
2 fans on 1 header ITaoI Air Cooling 1 August 26, 2009 06:50 PM
how many fans can I run off of motherboard cpu fan plugin Shadowmeph CPU's and Motherboards 3 August 5, 2009 01:17 PM
Connect case fans to the motherboard? Dogger1 Air Cooling 8 February 28, 2009 12:32 AM
