Old December 4, 2010, 09:48 AM
Default i7 970 OC with 3 DIMM vs 6 DIMM
Just a question regarding OC the LG1366 with 3 DIMMs vs 6 DIMMs. I would love to get 12GIG of ram for photoshop and premier usage, but I also want to OC the CPU over 4.0GHZ. I had the i7 870 before, and i had so much issue overclocking with 4DIMM compared to 2 DIMM. I was able to to hi 3.8ghz with 2DIMM and sadly only 3.6GHZ with 4DIMM.
I'm not sure how different overclocking is with LG1366, but would having 6 DIMMs significantly hindering my overclocking ability? Suggestions are welcomed.
Thanks in advance
Old December 4, 2010, 10:26 AM
lowfat's Avatar
It is really CPU depandant but generally it shouldn't be a problem. I ran up to 237bclk (4.8GHz) w/ all 6 DIMM's being used. Do you already have the ram or something? 4GB sticks aren't really expensive anymore, so there is no real reason to go w/ 2GB sticks.
Mael
Big Lian Li
Forever Alone
Old December 4, 2010, 11:03 AM
I have 3 DIMM (bought off lcdguy), but he has another 3 DIMM for sale. THinking if i should add another 6gig on to my setup that's all.
Old December 4, 2010, 09:52 PM
if you gonna run with looser timings you be ok
i have 6 stix of redline 6-7-6 stiff
doin 1720mhz @ 6-7-6 and with 6 stix i had to loosen to 6-8-6
i can do 1800 cas6 but not with 6 stix
if you runin cas 9 you be fine
you do notice a difference runnin with tight timings;)
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old December 4, 2010, 10:03 PM
Hey! You are the person who bought two 4870x2 off me! I recognize your user name. Did any of them work, and I'm sorry if they both turn out to be bad. I just wanted to get it off my hand because I didn't want to test them
Old December 5, 2010, 12:18 AM
1 is working perfectly now
and was used for parts to fix another one
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old December 5, 2010, 05:11 AM
Ok fantastic :) glad to know that.
Old December 5, 2010, 06:04 AM
gingerbee's Avatar
never had a problem overclocking any of my 1366 gear with all dimms full
Old December 6, 2010, 02:26 PM
Really? That's good to know! I will try it then
Old December 6, 2010, 08:11 PM
Ctech's Avatar
Restricted Poster
Haven't seen any differences OC'ing with 3 DIMMs vs 6 DIMMs
[WTB] 1GB DIMM of DDR3 RAM Linus Buy/Sell & Trade 0 November 8, 2009 02:31 PM
[WTB] DDR1 SO-DIMM 1GB Modules qaz393 Buy/Sell & Trade 0 October 12, 2009 11:12 AM
One DIMM bad? ByteMe RAM 14 September 6, 2008 12:24 PM
Dimm Slots enaberif Overclocking, Tweaking and Benchmarking 3 March 10, 2007 01:23 PM
