Old December 28, 2007, 07:47 AM
Default QX9650
This was a quicky test, hardly any tweaks at all... I got home last night, tossed the chip in, set a few voltages (I can't even remember what they are set to), and left it running.
Sorry if the image is a bit wide. I didn't see any rules limiting width of images, and it views fine on 1280x1024.
That's my junky test rig. Next to work on for it? Toss my Accelero S1 onto the Sapphire 3870 (it's on my HIS 3870 which isn't clocking too well). Swap the PA120.2 for a PA120.3 (currently sitting in a box), and eventually find a case for it.
heatware
Old December 28, 2007, 08:31 AM
Babrbarossa's Avatar
Nice! Keep us posted.
Old December 28, 2007, 09:26 AM
Does anyone know if there are going to be any good 45nm dual cores that will be better than the "old" Quad cores with 65nm
Old December 28, 2007, 12:03 PM
Wankerfx's Avatar
First of all, that is one crazy chip! 4.0Ghz with 1.36V is nothing to sneeze at; you have tons of headroom, and I'm confident that you will reach ~4.2Ghz+ stable.
On XS, people have overclocked their E8400's/E8500's to 4.2Ghz+ on air, so I'm sure that they will compete against the old quads with ease, but I don't exactly know if they will outperform them.
[ER]
Old December 28, 2007, 02:31 PM
Prof. Dr. Silver's Avatar
Is it really running at 1.36V??? And how is the 4th core only running at 30C?
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old December 28, 2007, 03:07 PM
Yeah it's set at 1.375 or something in BIOS with Load Line Calibration enabled. I'm heading home soon so I'll fill in the rest of the settings.
Not sure why the 4th core is only 30C...All four cores are loading 100% in task manager. I did a sloppy job applying the thermal paste :P
heatware
Old December 28, 2007, 04:34 PM
belgolas's Avatar
And 8gigs of ram.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old December 28, 2007, 04:42 PM
magictorch's Avatar
Default Incredible chip
An amazing chip! I guess thats a new quadcore record for the forum
Old December 29, 2007, 10:39 AM
For my 10x400 Overclock above:
Ai Overclock Tuner : Manual
CPU Ratio Control : Manual
- Ratio CMOS Setting : 10
FSB Frequency : 400
FSB Strap to North Bridge : AUTO
PCI-E Frequency: 100
DRAM Frequency: DDR2- 800
DRAM Command Rate : AUTO
DRAM Timing Control: AUTO
DRAM Static Read Control: AUTO
Ai Clock Twister : AUTO
Transaction Booster : AUTO
CPU Voltage : 1.37500V
CPU PLL Voltage : 1.50V
North Bridge Voltage : AUTO
DRAM Voltage : 2.00V
FSB Termination Voltage : 1.30V
South Bridge Voltage : AUTO
Loadline Calibration : Enabled
CPU GTL Reference : AUTO
North Bridge GTL Reference : AUTO
DDR2 Channel A REF Voltage : AUTO
DDR2 Channel B REF Voltage : AUTO
DDR2 Controller REF Voltage : AUTO
SB 1.5V Voltage : AUTO
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED :
CPU Spread Spectrum : Enabled
PCIE Spread Spectrum : Enabled
I'm testing with 1.35000 V (CPU-Z loading at 1.336 V) right now and it looks ok so far.. I'm gonna see how low I can set vcore for 4 GHz :D
heatware
Old December 29, 2007, 11:09 AM
magictorch's Avatar
Default PLL voltage
Just out of curiosity-how do you know what to set for PLL voltage. I just leave mine on AUTO. I know if its too high (>1.7??) youll wreck a cpu.
Look forward to seeing updates
QX9650 @ 4.2 w/3870 CF zoob Overclocking, Tweaking and Benchmarking 10 February 7, 2008 07:53 PM
Intel Core 2 Extreme QX9650 45nm: TechGage Babrbarossa Reviews & Articles from the Web 4 October 31, 2007 05:32 PM
