  #21 (permalink)
Old December 27, 2007, 09:13 PM
belgolas's Avatar
that might work too but don't put water on it because water will leave little tiny particles on it like iron, sand, ect.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
  #22 (permalink)
Old December 27, 2007, 10:21 PM
Infiniti's Avatar
lol okay, what can i use to clean the backside of my cpu >.< some got on there too =/
  #23 (permalink)
Old December 27, 2007, 10:34 PM
belgolas's Avatar
the same stuff
Sponsor a child!
Fight poverty.
Qoute by Perineum
  #24 (permalink)
Old December 28, 2007, 03:34 PM
Infiniti's Avatar
Ok, I'm going out to the store today, so what do I get... Aerosol spray with electronics cleaner? I'm just making sure because I dont want to mess up my mobo and CPU.. lol
  #25 (permalink)
Old December 28, 2007, 04:30 PM
sswilson's Avatar
Yep electronic cleaner or contact cleaner in an aerosol spray can is what you should be looking for.
  #26 (permalink)
Old December 28, 2007, 04:39 PM
yycraven's Avatar
if you can find this kind of contact cleaner its the best
here is what it looks like Electro Contact Cleaner
we use this in our aviation electrical components.
I have 2 cans of this myself
  #27 (permalink)
Old December 28, 2007, 05:10 PM
Infiniti's Avatar
Your sure thats okay too right? Well... is it available at Canadian Tire?
  #28 (permalink)
Old December 28, 2007, 06:02 PM
sswilson's Avatar
Yeah the LPS is what I use at work as well and it's perfect if you can find it at a local store.
If not, I know for sure that the source sells cans of electrical contact cleaner.
  #29 (permalink)
Old December 28, 2007, 06:26 PM
yycraven's Avatar
The Source By Circuit City : Search Results
Canadian Tire
they both have contact cleaner, but I do not know these products as good as the LPS. LPS is the best, I use it on my motherboards and video cards to keep them clean.
LPS NoFlash is a vaporous solvent cleaner. It's nonconductive and nonflammable, so it can be used while equipment is in operation to avoid costly downtime. NoFlash Electro Contact Cleaner penetrates and evaporates quickly, dislodging oil, grease, dirt and other materials from precision mechanical and delicate electrical/ electronic parts leaving no residue.
  #30 (permalink)
Old December 28, 2007, 07:22 PM
Infiniti's Avatar
Where can I get LPS? Do I have to order it? And does it evaporate very fast? Sorry for all the questions, its just I dont want to mess up my computer since its still my first build and this has to last for a long time.
And how do I dispose of it? I cant flush it down the drain, it says so on the information sheet.
