Old November 15, 2010, 04:57 AM
sswilson's Avatar
After the first couple of boards I was starting to wonder if we'd finally seen the end to PCI support.... Must be a sign of things to come though, add-on card manufacturers are going to have to step up to the plate....
Great to see the inclusion of a molex for 4X folding, but what exactly is the last slot on that maximus? Is that a 4X PCIe???? Looks longer than a 1X, and it looks like the back end isn't closed so maybe a full length PCIe card will fit?
Old November 15, 2010, 06:29 AM
MarcusFoX's Avatar
Maximus 4 Extreme... Defently be picking one of these puppys up when these finally release. that quad phase memory and VRM voltage 16+2 controlled/regulation is gunna make these sandybridge cpu's super clockers.
A+ NET+ Linux+ LPIC-1 MCP MCTS MCSA MCITP
World of Tanks WGLNA
CSGO ESEA
Heatware: MarcusFoX
Old November 15, 2010, 07:12 AM
The Tac Vest looks nice, but why not allow a water block mount to take away heat from the nb/vrms?
heatware
Old November 15, 2010, 07:39 AM
MpG's Avatar
MpG MpG is offline
I didn't think was actually any silicon in the traditional NB position? Since it's all on-die now? So you'd pretty much have to mount the waterblock on top of the VRM.
@SKYMTL: With all respect to the NDA, is that 10C cooling improvement from the plastic shield verified? Or market-speak? While I can appreciate that it could funnel air to places hard for case-airflow to reach, it doesn't seem like a very efficient implementation.
Old November 15, 2010, 07:50 AM
CTA's Avatar
CTA CTA is offline
Originally Posted by MAC View Post
Completely new socket and completely new microarchitecture. Big changes
so will it perform x58+i7?
and when?
Old November 15, 2010, 08:52 AM
On the P8P67 Deluxe section it says "The Deluxe has three PCI-E x16 slots, supporting 2-way CrossFireX and 2-way SLI", wondering what the third slot is for if the board doesn't support 3-way SLI/CF?
Old November 15, 2010, 09:46 AM
I'm guessing there are only 16 lanes running off the processor. Hence the need for the PLX chip. Correct me if I'm wrong?
Edit: I'm a moron
Old November 15, 2010, 11:00 AM
The sabertooth x58 has three PCIe x16 slots, but the 3rd slot is only x4... I'm probably going to phyx mine eventually
Also, no love for 6 dimms?
  #19 (permalink)
Old November 15, 2010, 12:33 PM
Read on another article that the chipset only supports 16 lanes.. probably 16 on the CPU. I think some other boards will have the NF200 chipset to give it more lanes.
It's a shame because this board has the perfect layout for me, whereas the other with the NF200 does not. If only GPUs didn't need to be dual slot
  #20 (permalink)
Old November 15, 2010, 12:40 PM
MpG's Avatar
MpG MpG is offline
Only dual-channel on P67, so 4 slots will probably be the norm. We only got 6 slots with X58 because it supported triple channel.
Gigabyte Debuts Trio of Sandy Bridge Ready Motherboards FiXT Press Releases & Tech News 14 November 2, 2010 08:29 PM
Computex 2010: ASRock Details P67 Sandy Bridge Motherboard & More SKYMTL Press Releases & Tech News 0 June 4, 2010 08:15 PM
ASUS P7P55D Deluxe Motherboard Preview Comment Thread SKYMTL CPU's and Motherboards 14 August 26, 2009 03:11 PM
