Old November 13, 2010, 11:43 PM
BrianHanna's Avatar
Default idle i7 930 temps
Before i go into the overclocking part of my install, i just wanna make sure about these temps.
idle temps at 36/32/36/32
seem about right?
also, why is it showing 2.94 in cpu-z when i havent overclocked it? isn't stock 2.8?
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
Old November 14, 2010, 12:20 AM
Are those temps with a stock cooler?
i7 930 stock is 2.8, it's just one of your cores is running at 22x and that's what is reported in CPU-z, not sure why it does that but I am sure someone else knows on this forum.
edit: So the 22x multiplier triggers when you only use 1 of the cores. Not sure what intel tech enables this.
Old November 14, 2010, 12:28 AM
BrianHanna's Avatar
no, temps are with NCIX.com - Buy Noctua NH-U12P SE2 LGA775/1156/1366 AM2/AM3 I7/I5/PHENOM Heatpipe Cooler W/ 2XNH-P12 120MM Fans - NH-U12P SE2 In Canada.
ran prime95 (not for a stress test, just for 30mins to see max cpu temp)
at load max was 61/58/60/56
Old November 14, 2010, 12:29 AM
BrianHanna's Avatar
Old November 14, 2010, 12:32 AM
Yeah those temps are fine for that heatsink.
Old November 14, 2010, 03:05 PM
homer98's Avatar
You shouldnt really be worried about idle temps as long as they arent ridiculously high. its more about load temps, test with linx or prime95 or OCCT, whatever you want, but thats the true test to see if your cooler is working properly.
And as said before, the new intel cpu's have turbo boost, which increases the multiplier. thats why it shows ~2.94 Ghz, 133 x 22 = ~2.94
Old November 14, 2010, 07:54 PM
Soultribunal's Avatar
The clock is normal, though I set mine when clocking in my RAM to 21X133 which allowed for the 1600 Speed of my RAM.
Temps are normal too, i7's are hot chips (considering I came from cool running 775's and AM3's) and that is normal. I've got my i7 under water and my temps are better but not by much.
ST
www.realhardwarereviews.com
Old December 31, 2010, 07:11 AM
If you are worried about temps, and do not care to OC your CPU too much. You can decrease your multiplier and increase you BLCK to get your target CPU frequecy, this should end up decreasing your temp's at load time in most cases.
New CPU HS made load temps lower, idle HIGHER?? clone63 CPU's and Motherboards 6 July 20, 2009 10:31 AM
E8400 Idle temps? Realityshift Air Cooling 12 May 23, 2009 01:58 PM
idle temps for Q9550 SmogTown CPU's and Motherboards 10 May 14, 2009 10:41 AM
Post your IDLE temps! BrianHanna Cases 28 February 23, 2009 10:58 AM
E8400 Idle Temps... rjbarker Overclocking, Tweaking and Benchmarking 13 April 14, 2008 02:36 PM
