Old November 13, 2010, 04:01 PM
BrianHanna's Avatar
Default motherboard stuck?
i'm trying to remove my p5q-e from my case, but one of the mounting screws refuses to come out, as a result, i cannot get the motherboard out.
i think the mounting screw is stuck the screw that goes into the motherboard.
i cant hold the mounting screw in place tot get the other screw out, what the hell do i do.
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
Old November 13, 2010, 04:05 PM
Is the stuck screw at the edge of the motherboard? If so, can you get access to the motherboard standoff with a small pair of needlenose pliers?
Old November 13, 2010, 04:06 PM
BrianHanna's Avatar
the screw that stuck is the middle inside one
Old November 13, 2010, 04:10 PM
BrianHanna's Avatar
im going to try lift the motherboard from one end and hold the mounting screw witha pliers so i can screw out the motherboard screw
Old November 13, 2010, 04:12 PM
I don't suppose you don't have a 1/4" ratchet and socket to fit that screw, or a small nut driver.
Old November 13, 2010, 04:45 PM
ZZLEE's Avatar
1/4 inch flat rench taped to a ruler aor somthing lonstong nonconductive and wont scrach back of the bord ?
I f standoff comes though the tray enugh put a nut on it to hold it or anuther stand off. then nut driver or rnch tohold it. ??
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old November 13, 2010, 05:00 PM
3.0charlie's Avatar
Originally Posted by ZZLEE View Post
If standoff comes though the tray enugh put a nut on it to hold it or anuther stand off.
What he said. If you don't have a nut that fits the standoff thread size, just hold the protruding threads with a needlenose plier while you unscrew from inside the case.
Happens quite often with Lian-Li cases when I use those.
Hydro-Quebec is salivating...
Old November 13, 2010, 06:06 PM
Take the standoff with the motherboard then remove and place back onto the mobo tray. And then tighten all the standoffs with pliers so they do come loose from the mobo tray.
Old November 13, 2010, 06:57 PM
use a piece of paper on the inside of the plier to prevent scratches, not that anyone looks behind but still, not having little metal bits floating around is good :)
Old November 13, 2010, 07:47 PM
Take out all the other standoffs then just apply some upward pressure to the board and undo the screw.
Motherboards are more flexible than people think and this is usually enough pressure on the board to allow the screws to come out.
Stuck... Reyzac New Builds 16 August 26, 2010 11:03 AM
standoffs stuck on motherboard icepizza Troubleshooting 10 December 4, 2009 04:53 PM
WU Stuck! Apollo4g HardwareCanucks F@H Team 3 May 10, 2009 04:12 PM
WU is stuck punk_zappa HardwareCanucks F@H Team 6 April 5, 2009 06:32 PM
stuck sensor? kyle_L Troubleshooting 2 March 13, 2009 11:13 PM
