Old November 13, 2010, 08:42 AM
Default MSI 790FX-GD70 AM3 Help
Hello,
I'm building a new AMD pc and am kind of stuck at deciding what ram to get...
As it says in the title i picked
MSI 790FX-GD70 and in the specs it says DDR3 800/1066/1333/1600*/1800*/2133*(OC)
I took some 1600 ram with 8-8-8-24 timings (Note: I didn't post the brand or the name of the brand beacause on 3 previus forums they didn't answer my question and started to post me some Ram suggestion)
What does the OC in the Memory spec for the mobo mean?
Old November 13, 2010, 08:44 AM
sswilson's Avatar
OC in the specs means that it's beyond the "normal" operation of the motherboard chipset (what it was originally rated for / tested against).
In practice, all it means is that you'll have to manually increase the RAM multiplier in bios to get them to run at those speeds.
Old November 13, 2010, 08:48 AM
So I can use the 1600 ram but it won't run at 1600 but it will run at 1333?
Old November 13, 2010, 09:20 AM
sswilson's Avatar
At default. It's a simple matter of bumping the multiplier to get it to run at 1600.
Old November 13, 2010, 10:05 AM
hold on a sec, did you buy the board or not yet?
as for the ram speeds, dont be too stressed about it.
Old November 13, 2010, 10:07 AM
Soultribunal's Avatar
You may have to up the voltage a little too in order to get it running right. Depends on what the RAM is spec'd at.
I know getting my G.Skills running at their Rated rather than Default speed I had to up my voltage.
ST
www.realhardwarereviews.com
MSI 890FX-GD70 available for pre order @ NCIX AMD_PBz CPU's and Motherboards 6 April 20, 2010 02:30 PM
MSI 790FX-GD70 AM3 Motherboard Review Comment Thread SKYMTL CPU's and Motherboards 16 July 29, 2009 11:30 AM
which M.B is better::Asus m4a-79-t Deluxe OR MSI 790FX-GD70 kabal CPU's and Motherboards 11 June 10, 2009 08:53 AM
