Old November 12, 2010, 10:54 AM
Default x3440
Thinking about dropping some money on a new cpu.
I was looking at the x3440 it looks like a really depend cpu for the money. For $235 i don't think there is another CPU that has the same features for the same price range.
Any personally experiences?
Old November 12, 2010, 11:20 AM
hey dude. well its a good 25-30 percent cheaper than the next hyperthreaded quad. you get this cpu if you need the hp.
whats your current system, and what will you do with it? speak in percentages, like 80 percent gaming, 20 percent email.etc.
Old November 12, 2010, 01:48 PM
my current system? is needed upgrading. 780i, q9450
this cpu is gonna be paired up with a EVGA P55 SLi, at the moment i'm busy with school but once winter/summer holidays come i'd probably gaming most of the time.
i know HT won't have much effect on games at the this time, but i mutli task a lot, fold and have virtual machines running. So i need the extra threads.
Old November 12, 2010, 01:53 PM
go for it. what gpu and power supply do you have? could you get a giga ud3/4p? better board. the cheap p55 sli evga's are good with quads.
now, if you have money to buy just one thing, better off get a better gpu. at 1920 and above it will be the one determining factor. below that, cpu will make more difference.
Old November 12, 2010, 02:20 PM
Mushkin 650w 20a/4 rails
and EVGA GTX 470 :)
i have a 22" monitor (1680x1050)
thanks
Old November 12, 2010, 02:24 PM
youre good there..time to get a better lcd though. look for a sammy, or dell in special(at dell). 23/24 inch 1920x1080.
Gigabyte H55 + X3440 overclocking woes lowfat Overclocking, Tweaking and Benchmarking 25 December 7, 2010 10:11 AM
Difference between Xeon (X3440) and i5 750? lanken123 CPU's and Motherboards 4 June 7, 2010 01:31 PM
Xeon X3440? jdm89 CPU's and Motherboards 10 November 17, 2009 06:35 AM
