  #21 (permalink)
Old December 24, 2007, 10:26 PM
Digitaldemon's Avatar
No even the pioneer badge is supposedly outsourced to liteon.. but only certain components... of it.. pioneeer claims this is not true.. but it is hard to tell these days with so many companies outsourcing and many just leaving the business all together and refocusing their efforts.... benq.. last recommendation and good luck finding it a 1640 benq dvd burner
  #22 (permalink)
Old December 24, 2007, 10:30 PM
Nah everyone else borrows pioneers stuff.. even the Asus Quietdrives are re-badged pioneers.
  #23 (permalink)
Old December 26, 2007, 12:24 AM
Thanks for the advice all! You helped out big time!
Here's my first draft build... let me know if there's anything wonky that you see with this setup.
Proc: Q6600
Mobo: GA-X38-DQ6
RAM: OCZ 2N1066SR2GK pc8500 4 GIG*
Video Card: Asus EN8800GT (fastest GT I could find)
Sound Card: Audigy 7.1 OEM
HDD: WD Raptor 150Gig, WD Caviar 500Gig x2 (3 drives total)
Burner: Pioneer DVR-212D
Cooling: Thermalrite Ultra120 Extreme
Case: Whatever, anything with decent airflow and cheap.
PSU: Thermaltake Toughpower W0104RU 650W
* The OCZ ram is dirt cheap and the reviews say its great. Im just wondering if its going to work well on my board since my board is not the 680i chipset. I've also found the Corsair XMS2 Dominator as another option to go with. It' more expensive than the ocz sticks but is still superb.
Also, the board says its crossfire ready. Does that mean that i cant run my system using nvida video cards in SLI mode?
  #24 (permalink)
Old December 26, 2007, 12:44 AM
MpG's Avatar
MpG MpG is offline
Correct. The only chipsets that are able to SLI w/ Nvidia cards are the Nvidia chipsets (i.e. the 680i). Intel chipsets are restricted to Xfire multi-GPU setups. Of course, you can run any single GPU you want.
  #25 (permalink)
Old December 26, 2007, 12:58 AM
NCIX.com - Buy Thermaltake SopranoRS 101 Mid Tower ATX Case Black 4X5.25 2X3.5 5X3.5INT No PSU Side Window - VG7000BWS In Canada.
53 bucks at ncix after rebate 73 reg.. thermal makes some decent cases
and a better stable mobo
NCIX.com - Buy XFX Nforce 680I SLI Conroe LGA775 ATX 3PCI-E16 2PCI-E1 2PCI SATA2 Sound GBLAN 1394 Motherboard - MBN680ISH9 In Canada.
  #26 (permalink)
Old December 26, 2007, 02:56 PM
Bloops! AkG, for some reason I thought you were refering to the x38-DQ6. Switched the board to the p35-DQ6. Muuuch nicer.
Digitaldemon, thanks for the recommendations! I checked out the case and I'm not sure if the PS I have will reach (sigh more research lol). And it was your mobo suggestion that clued me into my error.
Thanks for the answers MpG.
Revisions:
Proc: Q6600
Mobo: GA-P35-DQ6
RAM: Corsair XMS2 Dominator TWIN2X2048-8500C5DF x2Gig (for now)
HDD: WD Raptor 150Gig x1, WD Caviar 500Gig x1
Edit: Ok, is there really any difference in using the OCZ 2N1066SR2GK SLI vs The Corsair XMS2? Does not having a SLI board limit the OCZ ram in some way since it's not using the NVIDIA Enhanced Performance Profiles?
New to OC and buying a new system... need advice Spblue Overclocking, Tweaking and Benchmarking 3 December 5, 2007 11:21 AM
Digital Photo Veiwer Supergrover Display Units 4 November 12, 2007 02:59 PM
TV Tuner to rec digital feed Wiked HTPC Systems & Software 4 October 14, 2007 12:40 PM
Need to buy a Digital cam! Patriote Peripherals 22 August 5, 2007 02:14 AM
10 things to consider about digital cameras Babrbarossa Reviews & Articles from the Web 2 June 18, 2007 12:12 PM
