Old November 7, 2010, 01:10 PM
kruzn4evr's Avatar
Originally Posted by bvsbutthd101 View Post
it should come with the stock fan, right?
Attachment 12089
That stock heatsink won't get him to 4.0
Old November 7, 2010, 01:13 PM
bvsbutthd101's Avatar
why does he have to overclock to 4.0ghz right out the box. He could overclock it to 3.2 or 3.4 with stock heatsink.
Old November 7, 2010, 01:17 PM
kruzn4evr's Avatar
Agreed, all I'm saying is $309 for a 930 and the Noctua is very nice deal and getting a 950 and then shelling out $50-$80 for a heatsink down the road won't yeild him any better results.
Old November 7, 2010, 01:31 PM
it is a good deal, saving $60. whatever one you go for, you won't be disappointed
Old November 7, 2010, 01:37 PM
rjbarker's Avatar
^^^^ Makes complete sense Robert.....I think way back when I paid around $80 for my TRUE, so that is a very good deal. Also, the comment about the I7 950 scoring higher in Vantage vs the 930 is complete nonsense when they're both OC'd to the same speed.
OP
You can purchase everything at NCIX and simply Price Match to the lowest price found (great all in one shopping).....also....
There a number of good deals floating around our BST Thread for used I7 gear...check it out!!!
For 4 Ghz you'll need a decent AHSF, certainly not stock!!
Firestrike Extreme: 21.452
MARK 11: 32.530
Old November 7, 2010, 01:44 PM
kruzn4evr's Avatar
+1^^....you could probably find a better used mobo here then the Sabertooth (not knocking it, I'm just saying). I guess it depends on how you feel about used vs new and what budget you have to work with.
Old November 7, 2010, 01:51 PM
OP
wait a sec, so when your buying a cpu for ex. the 930 and 950, the 950 cost more cause your paying for the higher clock speed?
Old November 7, 2010, 02:01 PM
rjbarker's Avatar
^^^ Exactly. ...you're paying for higher Mult (CPU "stock" clock speeds).....they're the exact same CPU...one is clocked higher than the other at stock. If you OC both to the same speed they're identical..you'll likely find that regardless of the Multiplier they'll both OC just as well, bearing in mind not all CPU's are created equal.
Example: The older 920 DO Chips OC like the banshee with lower Core Voltage.....the OP maybe better off finding a well priced used "proven" 920 DO..........
MARK 11: 32.530
  #19 (permalink)
Old November 7, 2010, 02:05 PM
kruzn4evr's Avatar
Yup....what he said...lol
  #20 (permalink)
Old November 7, 2010, 03:43 PM
BrianHanna's Avatar
Attachment 12089
i would never overclock with a stock fan, and i most def want to overclock to the 4ghz range
so yea, i went ahead and placed an order for the 930 combo.
I was thinking i5, but i really don't want to leave that upgrade path open, i really rather spend it now, than spend now, sell the parts then go to i7.
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
Max out the S775 or move up to I7? Dr_BenD_over CPU's and Motherboards 20 December 23, 2009 03:36 PM
T-Rad2 GTX the Best move I ever made MarkOne Video Cards 12 October 23, 2009 08:57 PM
Is it worth the move to I7? quikgp CPU's and Motherboards 31 May 14, 2009 04:31 PM
Cheapest way to move interprovincially? vulcan500rider Off Topic 11 October 5, 2008 10:41 AM
which one, and can i move it ? Unklmo Troubleshooting 4 June 30, 2007 07:23 PM
