Originally Posted by Eldonko Try a BIOS update, sounds like a BIOS issue. |
I have flashed to the latest bios edition, but I did seach around a little and found many have this problem and its just the board thinks there is a problem when there isn't and apparently raising the ram voltage a little helps..so my ram stock with the board is usually at 1.64v when its rated for 1.65v "mushkin blackline" but there is no 1.65v so i raised it to 1.66v I will see if that makes it a difference if it was a bios problem it might happen at stock clocks which it never did. Thanks for the idea though
