Old October 31, 2010, 06:05 AM
Nevakonaza's Avatar
Question Dual Ethernet Port
Ive noticed some motherboards have Dual Ethernet connections on the back,why is this?
I thought you could only use one at a time?
Old October 31, 2010, 06:25 AM
sswilson's Avatar
The only time I've found a use for it was for sharing internet with an Xbox 360 without having to run two long lengths of cat 5 from the router.
Old October 31, 2010, 06:57 AM
Nevakonaza's Avatar
ah so basicly it acts like a router/switch sort of thing that shares the connection?
i thought it would be so you can connect 2 ethernet cables from your router and get better transfer rates or something as both cables were been used :D
Old October 31, 2010, 07:04 AM
sswilson's Avatar
Pretty sure everybody thought that initially. ;) Unfortunately "merging" of two streams requires a lot more than just two connections. Quite frankly I'm not completely sure why every motherboard appears to come with two connections these days... maybe there's a use for the redundancy in business setups?
Old October 31, 2010, 07:16 AM
martin_metal_88's Avatar
They put two only to be extreeeeeme...Like buying a killer NC. The only reason I see for 2 network card is if you have 2 ISP for some reason and depending on your task you have to switch from on to another, then you could disable one tu use another....out of that, I dunno.
Old October 31, 2010, 08:46 AM
Keywork's Avatar
I believe most of these motherboards with dual NIC's support bonding, which means you can make the 2 act as one if you have a switch that supports Link aggregation.
Old October 31, 2010, 09:13 AM
as per above. also called "teaming".
Old November 8, 2010, 01:06 PM
Or if you want to mess around Windows Server 2008 and Hyper-V, you want to assign one NIC to your host OS while assigning the other one to hyper-v so you get better transfer rates from the host OS.
Old November 8, 2010, 02:09 PM
botat29's Avatar
you can connect on 2 different network. I do it.
Old November 8, 2010, 06:47 PM
2 nics on a board is one of the deciding factors for which board to buy.
so far it always has come in handy, plug in in external hardware i need for work, or just connecting another machine to it temporarily for doing diagnostics on or copying large amount of data.
I haven't yet used the "teaming" aspect of it.... yet
Mobo ethernet port isn't work... =( do I need to RMA? feerof Troubleshooting 10 May 3, 2010 01:39 PM
tp link ethernet switch lanken123 Networking 3 March 27, 2010 05:22 PM
[FS] Netgear 5-Port Gigabit Ethernet Switch norfolk Buy/Sell & Trade 2 May 25, 2009 01:20 PM
Marvell vs Realtek ethernet controller TheRock CPU's and Motherboards 5 March 2, 2009 07:46 AM
Gigabyte P45-DQ6 has four Ethernet ports Hardware Canucks Press Releases & Tech News 3 May 7, 2008 08:10 AM
