  #51 (permalink)
Old November 6, 2010, 12:12 PM
bvsbutthd101's Avatar
Originally Posted by vohiep84 View Post
Have you considered the Rasa kit?
Rasa 750 RS240 Complete CPU WaterCooling Kit [RASA750KIT] - $142.99 : DazMode, Canadian PC Water Cooling and Modding Store
Close to the price of a H70 and is a great entry water cooling kit.
I noticed you had a Haf 932 so you could mount the radiator internally.
I was thinking of custom water cooling, the building seems pretty straight forward but all the parts would cost around $450. Don't have that much to spend right now. But when I do custom WC, I'm gonna go with buying everything separate.
  #52 (permalink)
Old November 6, 2010, 12:49 PM
Well the kit itself is an entire loop for only $150 :-), so if you consider a H70 consider the Rasa 750 kit first.
  #53 (permalink)
Old November 6, 2010, 12:55 PM
might now even get on H70, probably gonna stick with my H50 for a while, my temps are ok now
Safe temps for e8400 E0 under 100% load? lanken123 Overclocking, Tweaking and Benchmarking 13 February 14, 2010 08:32 PM
What graphics cards can run Age of Conan maxed? Red Lite3 Video Cards 25 September 5, 2009 01:00 AM
New CPU HS made load temps lower, idle HIGHER?? clone63 CPU's and Motherboards 6 July 20, 2009 10:31 AM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
arctic silver ceramique application and opteron load temps magictorch CPU's and Motherboards 10 July 1, 2007 12:41 PM
