  #21 (permalink)
Old October 26, 2010, 10:12 AM
Originally Posted by mkultra View Post
not necessarily
i've runned 20pass of linx back in the days i was still believing and crashed while playing cod4, that's when i lost faith
I am sure many can get away with running games on an unstable system as most gaming does not stress the computer heavily [/quote]
you'd be surprise, of course i'm talking the games i'm playing cod4-5/bfbc2/dirt2/f2010
they don't load your cpu @ 100% load but they requires stability, and that is cpu/ram/gpu at the same time(because yes i run with all 3 OCed). I never been able to play one of those games more than an hour or 2 when not stable.
encoding a bluray in h264 for 10-20hours ~100% load demands stabilty, cpu AND ram.(this is usually my final test)
yes using linx/p95 does work but i think it's faster with my tools than letting my comp running overnight only to wake up on a BSOD. (when did it happen? what was the cause?...who knows i was sleeping) How many trial and errors can you make that way...1 by day? jeez talk about inefficiency
temperature concern is a thing i'm not used too anymore because i use watercooling only, my days of air overclocking are well behind me. With a good watercooling system you will hit a virtual wall before being limited by temperature.
another good way to test stability without "wasting" cycles is to fold , try it on an unstable system you'll see bsod and errors showing up soon enough, no need to wait overnight.
Sorry to hear you couldn't keep stable after 20 linx runs playing cod4.
Yes running games require complete system stability but he's only overclocking his CPU. Which he should only be concerned about his CPU and RAM, not GPU. He hasn't mentioned any of his bios settings yet so it's hard to determine if he is stressing his RAM.
You can check for BSOD errors in the windows event logger, you can also halt restarts on BSOD.
I can run my stability tests in 10-20 hrs so im not sure how your methods are any faster. I can do 9-10 sets of 20 Linx runs in 10 hrs.
Yes effecient overclocking takes time its for enthusiast not for the impatient.
I only do overnights when tweaking voltages for effecient stable overclocks.
Anyways these stress tools are available and easy to use and there are reasons why they exist and used by many.
To each his own.
  #22 (permalink)
Old October 26, 2010, 10:47 AM
Do memtest86 for 4-5 pass to make sure your ram is working properly, because most of the time it is ram that gives you bsod. Then i would do prim95 custom blend test with all remaining ram for 2-3 hours. My computer been rock solid stable if they pass those tests. Get a good book while you wait for those tests to finish. My load temperature under 3.8ghz oc is 75 (or 70 w/o the side panel) which i'm slightly happy about
  #23 (permalink)
Old October 26, 2010, 01:15 PM
rjbarker's Avatar
Some great points above why we Stress Test correctly and utilize the tools available based upon our own methodology of testing........certainly gaming or 20 passes of LinX is anything but "proven" stable for me, that is why I use LinX 20 passes to see where I stand..then run an overnight P95 Small FFT / Blend for rock solid piece of mind and NO, I have never had a BSOD while gaming after my methodology of testing.....but as was said...to each his own, although I do dislike seeing folks post up thier OC Templates when they haven't been "properly" proven stable....its simply misleading.
Yes, stable OC's can take some time....in fact I was working on tweaking my 980X to 4.15 Ghz for a few weeks to find the absolute sweet spot.....its the nature of the beast, but I do know I will not suffer any BSOD's nor will my friends , relatives or clients that I tweak for!
Classified SLi "Procyon II"
http://i30.photobucket.com/albums/c3...psafdd5ead.jpg
http://i30.photobucket.com/albums/c3...ps14a68ad9.jpg
3DMK 11
http://i30.photobucket.com/albums/c3...pse3993acf.jpg
Valley
http://i30.photobucket.com/albums/c3...psc01f1ceb.png
  #24 (permalink)
Old October 26, 2010, 01:29 PM
bvsbutthd101's Avatar
i 100 percent agree with you, I just order some IC Diamond thermal paste, waiting for that to come in to replace the artic silver I got, but I decrease the QPI voltages and it lower temps dramatically, still not stable yet, gonna work on it some more.
  #25 (permalink)
Old October 26, 2010, 06:13 PM
memtest86 for 5 passes, passed with no errors :)
  #26 (permalink)
Old October 26, 2010, 07:57 PM
rjbarker's Avatar
^^^ Good stuff......now hav you disabled VDroop and tried 1.3v (vCore) ? If you try it, and it fails try 1.325v.....leave VDroop Disabled and note (write down) what the vCore Load is while stressing....you'll notice it goes "up" a little bit from what you set in the BIOS as apposed to going down a lot with Droop enabled.
3DMK 11
Valley
  #27 (permalink)
Old October 26, 2010, 08:31 PM
lowfat's Avatar
Because 20 passes isn't near enough. 20 passes can take as little as 30 minutes depending on amount of ram you have. Of course such a short time will not check all that much for stability.
  #28 (permalink)
Old October 27, 2010, 03:57 AM
6gb is kinda long i think, running linx with anything but max mem is a worst thought than using linx itself
  #29 (permalink)
Old October 27, 2010, 12:28 PM
ill try 1.325 v now, and yes I have vdroop off, currently my VTT is at 50 mv and QPI at 1.125
  #30 (permalink)
Old October 27, 2010, 01:01 PM
tried 1.325 v, still failed running P95, the voltage at load was .9028 v
Safe temps for e8400 E0 under 100% load? lanken123 Overclocking, Tweaking and Benchmarking 13 February 14, 2010 08:32 PM
What graphics cards can run Age of Conan maxed? Red Lite3 Video Cards 25 September 5, 2009 01:00 AM
New CPU HS made load temps lower, idle HIGHER?? clone63 CPU's and Motherboards 6 July 20, 2009 10:31 AM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
arctic silver ceramique application and opteron load temps magictorch CPU's and Motherboards 10 July 1, 2007 12:41 PM
