Originally Posted by MpG I've seen numerous reviews of OCZ's flex memory, where they determine that watercooling does nothing but slightly lower internal case temperatures. Best bet is to just have a small fan assembly blowing on them.
I don't quite get that Inq article... didn't Hipro5 get 4.5 Ghz out of one of the new chips with nothing but an air cooler?
EDIT: Almost forgot. Double-check that whatever case you choose will hold the board. IIRC, at some of the Maximus boards are an inch wider than standard ATX form. |
Thanks,about that case,it will hold extended ATX as well here it is:
SwordM VD500LBNA
let me know what you really think about this case please,i want the best case available with the most space and ventilation possibilities money can get.
If you feel it's useless or ugly or any other opinion concerning this case,please say so.
I want my first water cooled rig to be already set up for the cpu and chipset cooling.
Once i learn more about water systems and come to get familiar with it all,i will build an extra cooling system,another loop to go with all the upgrades i will put inside during the next months.
As you can see,i will require a lot of help in the water cooling and overclocking department lol but i love a good challenge and this one seems to be the biggest i have ever undertaken. thanks!
