  #31 (permalink)
Old December 20, 2007, 09:45 PM
Good to hear; come back to us once you are ready to order.
Thanks!
I'm planning on ordering,december 26 right after christmas just to see if i could get a better deal,plus i dont want to rush anything cause if i want to add or modify my BIG list for santa's this X-mas,i will still be able to.
This year christmas is going to be a couple weeks late but i dont mind the wait cause i know when i get my rig,i'm not gonna sleep for 4 or 5 days straight so i better get some rest right after the hollidays cause after that,it looks like i'm gonna be ONLINE for days on end if not weeks.
I'll keep everyone posted
Until i change something,this is gonna be my final rig within the next month
1 x PC ASSEMBLY AND TESTING (PRE-CONFIG OS IF PURCHASED)
1 x Intel Core 2 Quad Q6600 Quad Core Processor LGA775 Kentsfield 2.40GHZ 1066FSB 8MB Retail Box
1 x ASUS Maximus Extreme LGA775 X38 ATX DDR3 2PCI-E16 2PCI-E1 2PCI 2GBLAN 1394A SATA RAID Motherboard
1 x OCZ Reaperx Hpc Edition PC3-10666 DDR3 4GB 2X2GB DDR3-1333 CL6-5-5-18 Dual Channel Memory Kit
2 x Visiontek Radeon HD 3870 512MB GDDR4 PCI-E Dual DVI-I HDCP HDMI HDTV Out Video Card
1 x Zalman CNPS9700NT Copper CPU Heatsink 110MM Fan LGA775 AM2 S939 1250-2800RPM 19.5-35DBA Green LED
1 x Mountain Mods U2-UFO Horizon Powder Coat Black Wrinkle ATX Cube Case 6X5.25 6X3.5INT Original Top
1 x PC Power & Cooling Silencer 750 Quad Crossfire 750W ATX V2.2 EPS12 24PIN Active PFC Power Supply Red
2 x Western Digital Raptor 74GB SATA 10000RPM Hard Drive 5.2MS 16MB NCQ 5 Year MFR Warranty
1 x Western Digital SE-16 320GB 3.5IN SATA2 7200RPM 16MB 8.9MS Hard Drive OEM 3YR MFR Warranty
2 x Samsung SH-S203B Black SATA DVD+RW 20X8X16 DVD-RW 20X6X16 DL 18X/12X INT DVD Writer OEM W/ Vista SW
1 x Microsoft Windows Vista Ultimate Edition 64BIT DVD OEM
1 x AuzenTech X-FI Prelude 7.1 Sound Card PCI 32BIT Eax 5.0
1 x nGear Flash Card Reader 3.5IN Internal USB Black CF/SM/SD/MMC/MS/XD 18IN Cable Seperated Connectors
1 x Tritton AX360 5.1 Surround Sound Gaming Headphones W/ External 5.1 Dolby Digital Prologic Decoder
P.S. i'm ordering the rig with a cpu fan cause i need it for my old pc.
WC SYSTEM(for now):
Thermochill Pa 120.3 Triple 120MM Fan Water Cooling Radiator *No Barbs*
D-TEK Customs Fuzion CPU Water Block S478/LGA775/S939/AM2/S754 1/2IN Barbs
Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings
Magicool Thermochill Mounting Screws 3.5 X 40MM (4 Screws)
Thermochill 1/2IN Chrome Plated Barb Fitting G3/8 Threads *Single Barb*
D-TEK Customs 1/2IN G1/4 Chrome High Flow Barb Fittings (Pair) Fluid XP+ Extreme Green NON-CONDUCTIVE Water Replacement
EXTRAS:
Zalman ZM-MFC2 4 Fan Speed Controller 5.25IN Bay W/ Backlit LCD Display & Watt Meter
NCIX VIP MEMBERSHIP FEE PER YEAR
tell me what you think!
Last edited by SagManQc; December 20, 2007 at 09:50 PM. Reason: reason for ordering the cpu fan
  #32 (permalink)
Old December 21, 2007, 03:56 AM
llama_egg's Avatar
Are you actually buying the VIP membership? It's free with 500 points. And if you want a chance at better deals, you might want to look at PP instead of VIP if your not using points to get it.
Other then that, I don't see much I would change, and I can't wait to see the benchies on it! That and I hate you for getting that case...it's so sexy looking! :D
  #33 (permalink)
Old December 21, 2007, 06:30 AM
3.0charlie's Avatar
I have a couple of suggestions:
no need for pre-assembly.
I would wait as long as possible for the new breed of CPUs, or go for the QX9650. With a rig like yours, the Q6600 is the bottleneck.
change the ram for the Dominators
change the PSU for a modular version, like this one: NCIX.com - Buy Silverstone Strider ST1000 1000W Modular Power Supply ATX 20/24PIN 135MM Fan High Efficiency Black - SST-ST1000 In Canada. or this one: NCIX.com - Buy Enermax Galaxy Dxx 850W Power Supply ATX V2.0 EPS12V SLI RoHS 24PIN 135MM Fan Modular 4PCI-E - EGX850EWL In Canada..
for the wc system:
fans, fans, fans
7/16" or 1/2" tubing
NB block, GPU blocks
1/2" clamps - I hate worm gear clamps and tie-wraps on tubing.
use Swiftech's liquid solution. It's good enough.
Try to find a deal for free (or 9.99$) ground shipping - that MM case will cost a bundle in shipping.
Hydro-Quebec is salivating...
  #34 (permalink)
Old December 21, 2007, 04:03 PM
edit: i dont know what your reffering to when you talk about points and that the VIP with 500 points!
edit: Thanks, I'll be sure to post pics and 3dmark results for you guys to see.
edit:That's the plan,wait for the new CPU's to come out and then get one.
edit:I planned on having 4 Gb.Would 2 Gb of the Dominator(listed in previous posts) be better than the 4Gb of OCZ?
I've changed the PSU,it was a mistake a made when i update the list the last time,here's the final PSU unit is: Thermaltake Toughpower 1000W ATX12V V2.2 20/24PIN CrossFire Power Supply 140MM Active PFC Modular
for the wc system:
fans, fans, fans(added)
7/16" or 1/2" tubing(added)
NB block, GPU blocks(added)
1/2" clamps - I hate worm gear clamps and tie-wraps on tubing.edit:(added---i thought worm drive were a better fit but i dont know shit,remember)
use Swiftech's liquid solution. It's good enough.(added---Is it non-conductive like the other product is?
How can i find a deal at 9.99$ for that case to be shipped at my house in Saguenay?
Is there a company out there that would ship such a beast for 10$ at my house?
Thanks for all the input guys,i'm getting there real fast and you guys are making it happen for me.
Eric
  #35 (permalink)
Old December 21, 2007, 05:51 PM
3.0charlie's Avatar
Depending on which component you choose at ncix, some offer a special rate for ground delivery across Canada - 9.99$ or even free ground shipping.
  #36 (permalink)
Old December 21, 2007, 08:15 PM
Thanks
Maximus Formula RAID? JD CPU's and Motherboards 9 January 16, 2008 08:20 PM
Asus Maximus formula or ABIT iX38 quadGT silverchair CPU's and Motherboards 14 December 27, 2007 07:23 PM
ASUS Maximus Extreme Question? LegendofJubei CPU's and Motherboards 9 November 23, 2007 10:11 PM
ASUS Maximus Extreme x38 Babrbarossa CPU's and Motherboards 0 November 17, 2007 10:30 AM
Optimus Maximus keyboard in 15 days Supergrover Press Releases & Tech News 8 May 5, 2007 05:15 AM
