Old October 15, 2010, 01:12 AM
Default How much better will the new cpu be ?
My current CPU is a Pentium D 930.
The new CPU I'm going to be getting is a Pentium Dual Core E6500.
The Question is how much better is the E6500 over the Pentium D 930 ?
P.S.
I'm also upgrading my Graphics card from a 9800GT to a GTS 450.
Old October 15, 2010, 02:17 AM
in terms of performance and wattage per mhz, superior. its a core 2 architecture afterall.
does your old mobo support the new cpu? full specs please.
wait a little bit on the gpu purchase...give or take a week or two.
Budget CPU for Enthusiasts: Intel Celeron E3300 Processor Review (page 2) - X-bit labs
Budget CPU for Enthusiasts: Intel Celeron E3300 Processor Review (page 5) - X-bit labs
Budget CPU for Enthusiasts: Intel Celeron E3300 Processor Review (page 8) - X-bit labs
do get the 3300, its the same, a little bit slower at stock but overclocks just as good.
it ll do easy 3.2 on stock, higher if you dont mind the stock fan noise.
edit : same if you dont mind 1 meg of cache. for a value cpu it doesnt matter much.
Old October 15, 2010, 07:00 AM
JD JD is online now
E6500 will be quite the bump in performance, and power savings. Though you may want to consider other chips depending on what your motherboard supports.
I'd look at the E5400 personally.
Old October 15, 2010, 11:04 AM
My Motherboard is the Asus P5E it has the X38 chipset.
The CPU's supported by my Motherboard are as follows.
Core 2 Quad
Core 2 Extreme
Core 2 Duo
Pentium Extreme
Pentium D
Pentium 4
It also supports Next-gen 45nm multi-core CPU's.
P.S. The OS I'm running is Win 7 64-bit.
Old October 15, 2010, 11:56 AM
Soultribunal's Avatar
I would upgrade, I think the old D's were netburst or whatever it was called back then. The new 45nm dualies are really a good upgrade from what you have now for a good net in performance.
I would go with JD's suggestion if your board supports it.
ST
Old October 15, 2010, 12:02 PM
JD JD is online now
Well that's a solid board.
Why don't you look at a Core 2 Quad instead? Something in the 9x50 series would be ideal. 9x00 would be okay too, but I'd pass on the 8x00 series.
Old October 16, 2010, 12:52 AM
I only have a total of $275 CAD to get a newer CPU and a DX11 Video card.
Old October 16, 2010, 11:12 AM
JD JD is online now
Personally, I don't think going from a 9800GT to a GTS450 is worthwhile. There's honestly no need for DX11 right now.
If your going to upgrade, you need to go with at least the GTX460 or HD5770 (but ATI has new cards coming in a few weeks).
If you want a cheap CPU though, grab the E5400. Goes for like $70 new.
Old October 16, 2010, 02:40 PM
Dr_BenD_over's Avatar
DX11 ain't that great right now. If a 450 is your upgrade path, stick that cash into a better CPU (make sure to upgrade to the latest BIOS first though)
If it's stupid and it works, it isn't stupid.
Old October 16, 2010, 03:14 PM
275cad? you can catch a good deal on a 5870 :)
[Review] 2010 CPU Blocks RoundUp - Supreme HF, Apogee XT, Koolance CPU-360 and HK 3.0 Dazmode Water Cooling 3 May 29, 2010 06:52 PM
Can I add a cpu with slightly diff speed rating to existing single CPU config? HoTiCE_ CPU's and Motherboards 3 April 1, 2010 08:52 PM
CPU and cpu block questions miggs78 Water Cooling 7 August 10, 2009 01:14 AM
which temps are correct? cpu, cpu core1? Shadowmeph Overclocking, Tweaking and Benchmarking 4 July 13, 2009 06:23 PM
CPU use @ 57% and inactive processe use 93% of the CPu WTH ebdoradz Off Topic 6 February 26, 2008 06:34 PM
