Old October 17, 2010, 09:03 AM
Delavan's Avatar
Try to grab a quad, especially if you keep your CPU a long time...
Second-hand or brand new...Q8300 ($155 at the egg) or Q8400? a little overclockin' on top of that down the road?
I agree with others...go either GTX460 or 5770...the GTX450 is not really appealing to you...the 5770s are selling for cheaper and cheaper ($135-140 after MIR), especially because the HD6***-series are coming out...
DAN???? Where do you find 5870s for $275 again? Craig's?
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old October 17, 2010, 09:39 AM
jcmaz's Avatar
If you are really on a budget, just get a E21X0 dual core and OC the hell out of it :) You can probably get them for dirt cheap. Then spend the rest on a GTX 460 768MB
-Plato
Old October 17, 2010, 01:56 PM
ive seen at 250. maybe the scare of 'better' stuff coming out.
Old October 17, 2010, 04:22 PM
Wurmer's Avatar
A quad would be a nice upgrade but I think that a E 8400-8500-8600 could be a viable option if you can find one used on the cheap. Even if they are yesterday's favorites, they stil have plenty of power for decent gaming. Coupled with a decent GPU, you should end up with something that will suit your needs.
Old October 18, 2010, 12:46 AM
Is my current CPU the Pentium D 930. Classed as a 32-bit or 64-bit Processor.
Old October 20, 2010, 04:00 PM
Soultribunal's Avatar
Both, I think. I'd have to dig up some info to be certain.
Regardless Find a nice new dualie or used quad that your board supports. And Grab a GTS450.
I still think thats a good upgrade path for you.
ST
www.realhardwarereviews.com
Old October 20, 2010, 04:30 PM
Dr_BenD_over's Avatar
Fallen Folder
Pentium D's were 64bit
www.neeyik.info - AMD & Intel CPU Specifications
All's well that's Haswell
Old October 21, 2010, 05:36 PM
I ordered the Pentium Dual Core E6700 3.2GHz today from the NCIX website at around 2:30pm PST.
  #19 (permalink)
Old October 30, 2010, 04:19 PM
if i were you i would save up money and not buy the 450 gts
NVIDIA
it is NOT that much faster than a 9800 gt.
8800 gt = 9800 gt
will it be better at some things ya sure
will you be like wow what a difference, no you won't
you need to save up for a 460 gtx / 6850 minimum to be able to go
OH WOW amazing
  #20 (permalink)
Old October 30, 2010, 07:43 PM
rjbarker's Avatar
Minimum GTX 460.....save save save ;)
Firestrike Extreme: 21.452
MARK 11: 32.530
[Review] 2010 CPU Blocks RoundUp - Supreme HF, Apogee XT, Koolance CPU-360 and HK 3.0 Dazmode Water Cooling 3 May 29, 2010 06:52 PM
Can I add a cpu with slightly diff speed rating to existing single CPU config? HoTiCE_ CPU's and Motherboards 3 April 1, 2010 08:52 PM
CPU and cpu block questions miggs78 Water Cooling 7 August 10, 2009 01:14 AM
which temps are correct? cpu, cpu core1? Shadowmeph Overclocking, Tweaking and Benchmarking 4 July 13, 2009 06:23 PM
CPU use @ 57% and inactive processe use 93% of the CPu WTH ebdoradz Off Topic 6 February 26, 2008 07:34 PM
